Can Light Install - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 05:31 PM   #1
Can light install
Hi all.
Installing a can light (Thompson DY 6412 shower housing/trim kit).
The wiring part I've got under control, but I am sitting here scratching my head about the way the thing goes together.
It's a kit that can be used either for new or old work. It didn't come with directions.
See the picture for what I've got here.
The box obviouly goes on top of the can.
The trim has these springed-arms that dont seem to line up with anything.
I assume the plate with the slot for the rails I dont use in this setup.
Then there are these 4 big clips and these 3 tiny clips and four screws.
Anyone know what goes where?
schnitz411 is offline   Reply With Quote
Old 07-10-2010, 05:55 PM   #2
Retired Moderator
Rewards Points: 7,174
Please--do your self a favor and return that---Buy Halow or another quality brand--those are not worth installing.---Mike---
Old 07-10-2010, 06:13 PM   #3
That bad eh?
This sound good?
H7RICT OR H7RICAT
+ 172SNS trim?
(about same size, has the nickel trim i need, shower-rated and for remodel).
Should I even ask why the Thomas stuff seems to cost twice what the HALO i just looked at costs?
Old 07-10-2010, 07:21 PM   #4
Retired Moderator
Most of the Thomas lights that I have seen are a nightmare--sort of a combination,remodel/new construction compromise. Little bitty clips that will not stay in place,metal parts that are thin and just don't fit together well ---poor quality.
If you choose to use that you will be frustrated to tears.---Mike--
Old 07-10-2010, 07:25 PM   #5
Well I had to put it in at least temporarily (showering in the pitch black is just not very practical....), but I see what you mean...really poorly made - and gapping from the ceiling.
Will be replacing with HALO...or something else good. What are my other solid choice?
Thanks!
Old 07-10-2010, 07:38 PM   #6
Retired Moderator
Juno--Halo--even Commercial Electric at the depot.
What you want will say--IC (insulation contact)--air tight.
Also the light in the shower should be on a gcfi circuit.--That is easily wired to the LOAD side of the bathroom gcfi outlet.
There are a bunch of electricians here---hopefully one is on now and can clear up any thing that I may have confused you with.---Mike---
Old 07-18-2010, 05:22 PM   #7
Electrician
Proby's Avatar
There's no code calling for a high hat to be GFCI protected. Some people do it, but it's not necessary. If you use the GFCI receptacle to protect it, be aware that if the receptacle ever has a ground fault, you will loose the light too.
The only fixture I have ever seen that required GFCI protection is an exhaust fan mounted above the shower, but that is required by the manufacturer, not the code.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
oh'mike (07-18-2010)
Old 07-18-2010, 05:30 PM   #8
Retired Moderator
Some of our local codes do require any fixture above a tub or shower to be gcfi protected.
Good to always check local codes.
Old 07-18-2010, 05:44 PM   #9
Electrician
Proby's Avatar
Yeah, I should have mentioned that some municipalities might require funny things.
Old 07-18-2010, 05:47 PM   #10
Retired Moderator
I'm in Illinois---Cook and DuPage countys are still all conduit--No Romex--Lots of unique codes around here. Keeps a person on their toes.
Old 07-18-2010, 05:52 PM   #11
Electrician
Proby's Avatar
Yeah, you guys pretty much write your own electrical code, it's very strict. I can't imagine piping houses
Old 07-18-2010, 05:55 PM   #12
Retired Moderator
You just keep saying to your self--$55 an opening -is that enough?
Old 07-18-2010, 10:41 PM   #13
" Euro " electrician
frenchelectrican's Avatar
I did see that type of recessed can and that type I am not a strong fan of that one and I have dealt with it before and IMO that one of few worst products I have run into the two issue is the top box where the conductors will be hook up and second issue is the remodel clips they don't always hold well at all.
I rather use the Juno or Halo I know it cost more but in long run they are well built for the money worth.
And easy to find proper parts as need to.
Now speaking of RCD { GFCI } yes and no depending on how high the shower recessed luminaire mounted if over 7 or 8 foot then you don't need it unless the local code say something else.
The fart fan { exhaust fan } gernally will say yes with RCD due the manufacter requirement.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
oh'mike (07-19-2010)
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
My light fixture / socket question. Getson Electrical 13 02-25-2009 03:41 PM
Trouble with install of light fixture cmonsterjr Electrical 5 12-28-2008 07:06 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
