Can I Use Tandem Breakers. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 07:56 AM   #1
Rewards Points: 256
Can I use tandem breakers.
I have a full 100amp Square D series E7 panel: Does this panel allow the use of tandem breakers.
I have a 100 amp panel that is full.
I am adding central A/C. The HVAC guy suggested tandem breakers.
In my mind I was going to add a sub-panel or remove the un-used electric dryer hookup.
I know some panels alow tandems others do not.
michaelcherr is offline   Reply With Quote
Old 04-27-2011, 08:01 AM   #2
Licensed electrician
Rewards Points: 3,766
Sorry, did not see the model number the first time. That is a 20 circuit panel. No tandems allowed.
Old 04-27-2011, 08:09 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I believe that is a 20 space, 20 circuit panel, which means no tandems.
If your dryer circuit is unused, the cheapest route is to use it for the AC. But that will fill your panel and allow no future growth. Might be well to bite the bullet now and use the dryer circuit to add a sub-panel.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 04-27-2011, 08:34 AM   #4
Rewards Points: 256
Thanks, that's what I though I would hear.
I will add a sub-panel.
Upgrade panel, add subpanel, add tandem breakers? oregondiy Electrical 11 12-30-2010 10:45 PM
My 125A Square D HomeLine will not accept tandem breakers brons2 Electrical 3 11-01-2010 11:49 AM
SQUARE D TANDEM 15A SP Breakers 57_Hemi Electrical 6 07-30-2010 11:02 PM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 12:34 PM
