Can I Use This Switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 03:50 PM   #1
Rewards Points: 252
Can I use this switch??
I was thinking of using a switch like this to power the lights in my garage so I would be able to choose the amount of light I need.
However, if I install this switch in the current single gang box, wouldn't the box be overloaded? You can't have (4) 14-2 cables going into a single gang box can you? If not, how would you ever be able to use this switch in a single gang box??
mopowers is offline   Reply With Quote
Old 03-03-2010, 04:36 PM   #2
Just call me Andrew
Rewards Points: 1,032
Edit...I want to re-think my answer before I post, but check out this article:
http://www.selfhelpandmore.com/home-...tions-2002.php
Andrew
secutanudu is offline   Reply With Quote
Old 03-03-2010, 04:41 PM   #3
Just call me Andrew
I am thinking that the minimum size box you can use for that switch + (4) 14-2 wires would be 22 cubic inches.
2 cubic inches for each of the 8 current-carrying wires = 16
2 cubic inches for all the ground wires together = 2
4 cubic inches for the switch itself = 4
Total: 22
Like this box:
http://www.smarthome.com/25401/Singl...-Inches/p.aspx
Andrew
Old 03-03-2010, 04:43 PM   #4
Rewards Points: 81
you can use that switch. All you would need to make sure of is the box fill. you said you had four 14's correct? If so that would be 22 cubic inches. each 14 counts as 2 cubic inches. so you waould have 4 neutrals four hots and four grounds and 2 for the yoke. the grounds count as one so you would have 11 14's so 11 multiplied by 2 cu inches is 22. you would need a 22cu inch single gang box. This is only if you are using a plastic box. metal boxes are different because they can have clamps and other stuff too add to the calculation. Also pigtails do not count as box fill.
Chevyman30571 is offline   Reply With Quote
Old 03-03-2010, 04:45 PM   #5
Just call me Andrew
Beat ya!!
Andrew
Old 03-03-2010, 04:51 PM   #6
Rewards Points: 81
LOL. I type slow i have sausage fingers
Old 03-03-2010, 04:52 PM   #7
Rewards Points: 252
Thanks guys. How do I figure out what size box I currently have installed?
Old 03-03-2010, 05:27 PM   #8
Licensed electrician
Rewards Points: 3,654
Plastic boxes will have the cubic inch capacity stamped in the box. Metal boxes use the chart in the NEC unless stamped with the capacity.
Old 03-03-2010, 05:27 PM   #9
Many plastic boxes have a stamp at the inside-back of them indicating the size of the box is cubic inches. You'll likely find something along the lines of "18 cu.in.", with 20 and 22 being other common sizes.
HooKooDooKu is offline   Reply With Quote
Old 03-03-2010, 10:28 PM   #10
Rewards Points: 252
Thanks guys! I'll have to see how big the current singe gang box is.
If it is too small, is there a way to take out an existing box without having to cut out sheetrock? The current box is nailed to the stud on the top and bottom of the box. That way, I can just install a 3 gang box with 3 separate switches.
Old 03-03-2010, 10:31 PM   #11
Just call me Andrew
But those little triple switches are slick looking!
Andrew
Old 03-03-2010, 10:40 PM   #12
Rewards Points: 252
I know! Maybe I'll see if I can find an 'old work' single gang box that is 22ci at the local home depot or lowes.
Old 03-03-2010, 10:57 PM   #13
One trick to remove the box is to use a hacksaw blade on the stud side and cut thru the nails. be careful so as to not cut any cables stapled close to the box.
Old 03-03-2010, 11:10 PM   #14
Just cut the hole for the 3 gang box, pop a pry bar and push that box to the side. Those nails will pull right out. You will have plenty of room in a 3 gang cutout to get the box out.
gnosti83 is offline   Reply With Quote
Old 03-04-2010, 07:21 AM   #15
I hate anything more then a double box
I have one of the triple switches & the overhead fan/light switch in a double box
I usually only use the double switches
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
