Can I Use A Shorter Ceiling Fan Down-Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 03:10 PM   #1
Can I Use a Shorter Ceiling Fan Down-Rod
I have a fan that came with an 8-inch down-rod which is too long. Can I substitute it for a shorter one--a 4-inch one? Will the ceiling fan still function the same? What's the down-side of doing this?
Mililani is offline   Reply With Quote
Old 09-27-2010, 03:18 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the only thing to consider with a down rod change is: will it hit something because it is closer to the ceiling.
other than that, you can generally change the drop as you desire or needed.
Old 09-27-2010, 09:19 PM   #3
" Euro " electrician
frenchelectrican's Avatar
The only time I used the shorter downrod if the ceiling is flat or very shallow pitch.
As long you keep the fan blades 7 feet above the floor level you will be ok { most ceiling fan manufacters recomened that keep the blades at 7 to 9 feet level depending on how it set up }
Merci.
Marc
Old 10-08-2010, 12:46 AM   #4
Thanks for the good advice..... We did it and both fans work great! We used the drill press to drill the 2 holes in the rod. Sorry it took so long to respond.
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
