Can I Use An Existing 240V Line? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 06:32 PM   #1
STR
Can I use an existing 240V Line?
Parameters: Clothes dryer in utility room on 240V circuit. Need to add a 30A 120V circuit for an RV. Is it possible to continue using the existing 240V line (Red, White,Black & Ground) for the dryer and tap off one of the 120V using #10 wire (15' run) and install a 30A RV plug? Otherwise, I will need to run about 75' of conduit back to the main box which will be a big, big chore based on the house configuration.
STR is offline   Reply With Quote
Old 01-17-2010, 06:37 PM   #2
Inspector/Instructor
codeone's Avatar
Are you going to do away with your dryer. If not, NO you may not continue to your RV.
codeone is offline   Reply With Quote
Old 01-17-2010, 06:45 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 702
My daughter rented an apartment once that the dryer and the water heater were on the same 30 amp circuit. There was a big switch that you had to throw to run either the dryer or the water heater. Not recommended nor code compliant but it does show you what people will do.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 01-17-2010, 10:54 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
I had this in my house when I moved in, there is this heater under the garage to keep the foundation above freezing, and then the dryer. I ended up removing it and putting the header directly into the panel. I had to sacrifice 2 breakers to do it, but managed to consolidate some low use circuits into one. What I did was not code compliant here though as I went over the 12 outlet limit, but as far as safety goes it's safe - if I overload that circuit (mostly CFLs so it's unlikely) the breaker will do it's job (ok maybe not, they're stab loks LOL) and trip. When I upgrade my panel I will split them up. Guess you can say I broke one code to fix another lol.
Basically this is what I had and yes the dryer was hard wired in! Sounded like a rock crusher when I turned that thing on.
Gas line extension - black iron or copper?? Joshua77 Plumbing 27 10-24-2013 02:34 PM
Acceptable to run new 120v circuit in existing conduit carrying 240v? TomServo Electrical 4 10-22-2009 05:20 PM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 05:15 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
