Can I Trickle-charge My Portable Generator While Test-running It? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By 47_47
  • 1 Post By dmxtothemax
Old 11-10-2017, 09:26 AM   #1
Rewards Points: 6
Can i trickle-charge my portable generator while test-running it?
Hi- I'd like to test run my portable 4000/3500W genny for a couple hrs today because its had unwitnessed stalls the last 2 times i used it. I currently have power to my house but we're getting Wind storm today so I'd also like to trickle-charge the little starter battery. Can i hook up the trickle charger (to a household power outlet) after i get the genny running to do both tasks at the same time? Thanks.
Jald73 is offline   Reply With Quote
Old 11-10-2017, 09:38 AM   #2
47_47's Avatar
Rewards Points: 320
Re: Can i trickle-charge my portable generator while test-running it?
Your generator should charge the battery when running. I would not put two chargers on one battery at the same time.
Bondo and Bud9051 like this.
47_47 is offline   Reply With Quote
Old 11-10-2017, 10:29 AM   #3
Rewards Points: 6
Bonus! Thx
Old 11-10-2017, 05:40 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,850
Batteries don't like sitting around and not getting used.
If you want your batteries to last longer ?
You gotta use them more.
Regular use ensures maximum life.
J. V. likes this.
dmxtothemax is offline   Reply With Quote
Old 11-12-2017, 08:38 AM   #5
Rewards Points: 127
I make a practice of running my generator for 30 minutes every two months. Keeps the starter battery charged as well as testin it’s operation.
jimn01 is offline   Reply With Quote
Old 11-13-2017, 01:19 AM   #6
Rewards Points: 16
I always charge the battery of my generator even I do not need to run it fo rpower.
shelleywa is offline   Reply With Quote
Old 11-13-2017, 01:21 AM   #7
Rewards Points: 16
But there is still a question for me that I wanna find a good answer.
I’ve always heard that charging cordless tool batteries from a jobsite portable generator could ruin the batteries. If fact, I’ve seen it done.
But I’m wondering, with these newer generators with Digital Automatic Voltage Regulation, is this still an issue?
I know that the Inverter generators can charge them just fine, as well as running sensitive electronics.
Save
Old 11-13-2017, 08:58 AM   #8
Rewards Points: 600
Some generators do not charge their battery while running. My Generac does not. I have a Battery Tender Jr that I hook up once a month. I test start it every 3 months.
jreagan is offline   Reply With Quote
Camping Portable running water sink beh162 Plumbing 5 06-30-2015 05:55 PM
Carrier Cool & Heat 8.81 lbs Charge, comp. not running - fan is running justplumducky HVAC 23 07-27-2012 12:52 PM
Running Extension Cords From Portable Generator rkwingo Electrical 2 01-16-2012 10:58 AM
Running a portable generator 150' away from the house mrbillz Electrical 11 09-27-2011 09:51 AM
Trickle charger on portable generator - bad battery? timp Electrical 5 01-01-2009 07:46 PM
