Can I Tap Into This Romex? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 05-16-2019, 12:46 PM   #1
Rewards Points: 334
Can I tap into this romex?
I have replaced outlets, switches, fixtures, but have not added anything to existing romex.
I would like to mount a tv to the wall. Stud finder showed no studs, so I opened the wall and added some. I noticed the romex and I thought before I drywall I should look into adding an outlet right behind where the tv will be.
Can I add an electrical box, cut the romex, connect to a new outlet and by using wire nuts, reconnect the cut romex? Do I have to have a separate junction box for the wire nut connection?
Jamesonc is offline   Reply With Quote
Old 05-16-2019, 12:51 PM   #2
retired framer
Rewards Points: 15,614
Re: Can I tap into this romex?
Do you know what it is for or where it goes.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-16-2019, 12:59 PM   #3
Rewards Points: 334
Trial and error is the only way I know to find out what it is. There is an outlet to the left and right, close to the ground.
Old 05-16-2019, 01:03 PM   #4
retired framer
Not sure how you will prove it before you cut it but the wire will be too short so you might need a new wire from the next outlet to the new outlet.
figure 7-14
Old 05-16-2019, 01:20 PM   #5
Rewards Points: 334
Can't prove anything until I cut. If I do cut, to hook it back up I would use wire nuts and place this in a junction box, correct? From that wire nut connection inside the junction box I can attach more romex and connect to the outlet?
Old 05-16-2019, 01:25 PM   #6
Rewards Points: 334
I gave the romex a good tug and determined it is connected to at least the outlet on the right side.
Old 05-16-2019, 01:25 PM   #7
Rewards Points: 680
If you cut that romex you won't have enough slack to make a code compliant joint. To add an outlet here, install box and run new romex to the nearest outlet. Might require some sheetrock damage but you're already engaged in sheetrock repair here so no big deal.
LawnGuyLandSparky is offline   Reply With Quote
Old 05-16-2019, 01:29 PM   #8
Yes you can do that but donít bury the junction box in the wall. That splice will need to be accessible. Once you cut the romex, it will be too short to splice unless thereís enough slack to make a splice.
7635tools is offline   Reply With Quote
The Following User Says Thank You to 7635tools For This Useful Post:
Jamesonc (05-16-2019)
Old 05-16-2019, 01:31 PM   #9
Oso954's Avatar
Rewards Points: 1,882
Any junction box you install must be accessible.
You cannot put in a junction box and bury it behind drywall.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 05-16-2019, 01:36 PM   #10
retired framer
You would install 2 outlet boxes with a new wire between them, you could have 2 outlets or just put a black cover on one of them. You want 6" of wire in each box.
CodeMatters likes this.
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Old 05-16-2019, 01:36 PM   #11
Rewards Points: 334
Okay, thanks.
Just to confirm, cut drywall from outlet to where I want a new outlet, drill holes through studs, feed new romex and wire it up?
Old 05-16-2019, 01:37 PM   #12
Rewards Points: 58
Any junction box must be accessible after sheetrocking. You can add an additional plug where one of the wires will reach after cutting it, then run a new wire to the tv plug and on to the other existing plug ( by cutting more sheetrock or adding another plug).
Get a non-contact tester to verify the wire is off before cutting it.
Wiredindallas is offline   Reply With Quote
The Following User Says Thank You to Wiredindallas For This Useful Post:
Old 05-16-2019, 01:37 PM   #13
Rewards Points: 334
Nealtw, you're always helping out, thank you.
Old 05-16-2019, 01:44 PM   #14
Rewards Points: 334
This is good to know, thank you.
Old 05-16-2019, 04:12 PM   #15
Usually Confused
lenaitch's Avatar
Rewards Points: 2,100
Since you're going to the trouble, install a recessed receptacle intended for wall-hung TVs. You might even consider ones with audio connections and rough the wiring in while you have that wall open.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Tags
electrcal box , outlet , romex
THHN vs wires inside Romex stardogFB Electrical 7 03-06-2019 04:31 PM
EMT-protected Romex: sheathed or unsheathed TwistedJoist Electrical 21 03-25-2016 11:34 PM
Romex on basement wall to panel iceclimber2001 Electrical 3 08-13-2012 07:40 AM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
