Can I Get Constant Power From A 3-way Switch? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 05-06-2019, 01:46 PM   #1
Rewards Points: 297
Can i get constant power from a 3-way switch?
Hello
At the bottom of my stairs is a 3-way switch. There is a nearby closet that I would like to illuminate with a switched light.
Can I get constant power from that switch to supply another normal switch for that lamp? Or constant power to a lamp with a pull-string?
NABRIL is offline   Reply With Quote
Old 05-06-2019, 01:54 PM   #2
Rewards Points: 7,776
Re: Can i get constant power from a 3-way switch?
There are two 3-way switches and often one of them has the power feed. If that is the one close to your closet then possibly yes. But power could have been fed to the other switch or the light. If you take a look at the wires into that 3-way box and maybe a picture the electrical pros will be able to give you a definite answer.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
NABRIL (05-06-2019)
Old 05-06-2019, 01:54 PM   #3
Oso954's Avatar
Rewards Points: 690
Depends on how it is wired.
You need to pickup the constant hot and the neutral at the same point. Depending on what method was used to wire your 3 way, you may be missing either the constant hot, the neutral, or both.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
NABRIL (10-24-2019)
Old 05-06-2019, 01:55 PM   #4
Rewards Points: 58
It depends on if there is both hot and neutral at that switch box. You may only have 2 travelers and a neutral + switch leg out. 50/50 chance.
Wiredindallas is offline   Reply With Quote
The Following User Says Thank You to Wiredindallas For This Useful Post:
NABRIL (05-06-2019)
Old 05-06-2019, 02:02 PM   #5
Rewards Points: 297
Originally Posted by Bud9051 View Post
There are two 3-way switches and often one of them has the power feed. If that is the one close to your closet then possibly yes. But power could have been fed to the other switch or the light. If you take a look at the wires into that 3-way box and maybe a picture the electrical pros will be able to give you a definite answer.Bud
thanks guys. So, if I open up that switch box and can measure voltage at the black wire, does that mean that the hot is there?
Old 05-06-2019, 02:26 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 30,164
Not for sure.
If you open the switch and there are only three wires, all of them attached to the switch then no.
If there are more then three wires and there are two or more whites connected together and NOT to the switch then maybe you can do it. It depends if those wire are power in from the panel or power out to the light.
The Following User Says Thank You to joed For This Useful Post:
NABRIL (10-24-2019)
Old 10-25-2019, 01:28 PM   #7
Rewards Points: 297
I finally got around to exploring that junction box. There is 1 wire coming into the box, with a black, white, and red wire with nothing else.
So can i run a wire in there to power a switched light?
Can i get constant power from a 3-way switch?-img_20191025_132557_1572024411697.jpg
Old 10-25-2019, 01:31 PM   #8
Oso954's Avatar
Rewards Points: 690
No, there is no neutral in that box.
joed likes this.
Old 10-25-2019, 01:33 PM   #9
Rewards Points: 297
That white wire is not a neutral?
Old 10-25-2019, 02:08 PM   #10
Oso954's Avatar
Rewards Points: 690
No. If the white was a neutral, it would not be attached to a 3way switch.
joed likes this.
NABRIL (10-25-2019)
Old 10-25-2019, 02:09 PM   #11
Rewards Points: 1,714
No, it's not a neutral. It's a traveler wire that carries the switched hot between the 2 switches.
joed likes this.
RAL238 is offline   Reply With Quote
The Following User Says Thank You to RAL238 For This Useful Post:
NABRIL (10-25-2019)
Old 10-25-2019, 02:19 PM   #12
Rewards Points: 680
This is referred to as a "dead end" 3-way. Not only don't you have a neutral - the hot may change from one traveler terminal to the other depending on which state the other 3-way is in.
LawnGuyLandSparky is offline   Reply With Quote
The Following User Says Thank You to LawnGuyLandSparky For This Useful Post:
NABRIL (10-25-2019)
Old 10-25-2019, 05:24 PM   #13
dmxtothemax's Avatar
Rewards Points: 7,672
Constant power is onlt available at one end of a three way arrangement,
So it all depends on which end you got ?
dmxtothemax is offline   Reply With Quote
Old 10-25-2019, 05:28 PM   #14
Rewards Points: 297
It looks like this switch is the very end
Old 10-25-2019, 05:35 PM   #15
Super Moderator
joed's Avatar
Constant power is not always available at one of the switches. Power could be in the fixture and then constant power is not available at either switch.
rjniles likes this.
Adding a light to the end of a 4way switch circuit TheFutureYou Electrical 17 10-23-2018 08:33 AM
Eliminating a 3-way switch and replacing it with device needing power. Boss Tricky Electrical 0 12-14-2013 07:33 PM
Proper Wiring Power to Outlet to 3-Way switch to lighte msandrbs Electrical 7 12-10-2013 01:58 AM
3Way switch and power through DiegoJames Electrical 9 01-27-2013 02:00 PM
2 way switch mystery.. no power at switch but power at light when turned on vote4Pedro Electrical 18 06-27-2011 11:25 PM
