Can I Change A 220v Outlet To 120v And Use Existing 10awg Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2016, 06:51 PM   #1
Rewards Points: 87
Can I change a 220v outlet to 120v and use existing 10awg wire
I have a dedicated washer/dryer circuit running to my daylight basement.
30amp 220v breaker.
10awg wire.
However my plans are to install an all in one condensing washer/dryer that required a 120v circuit of at least 10amps. (No decent way to vent a regular dryer)
Can I change my outlet and breaker and keep using the 10awg wire?
Or do I need to come off something else in the bathroom that is already 120v?
Everything but the bathroom is enclosed so running a new wire would be pretty rough.
I will be talking to an electrician about this but wanted to get an idea of what I will need to do.
Thanks!
hellonoko is offline   Reply With Quote
Old 12-14-2016, 06:56 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,096
Re: Can I change a 220v outlet to 120v and use existing 10awg wire
It would not be against code to use #10 on a 15 or 20 amp circuit. You might need to pigtail some #14 or #12 to get the wire to fit a receptacle properly.
The Following User Says Thank You to joed For This Useful Post:
hellonoko (12-14-2016)
Old 12-14-2016, 07:05 PM   #3
Oso954's Avatar
Rewards Points: 660
As a laundry area, the 120v circuit needs to be 20amp and the receptacle must be GFCI protected, if you are in the USA.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 12-14-2016, 07:24 PM   #4
Absolutely you just can't go any bigger that a 30 amp single pole breaker.....does your existing wire have a ground....aka 10/3
dabears54
dabearsjoe420 is offline   Reply With Quote
The Following User Says Thank You to dabearsjoe420 For This Useful Post:
Old 12-14-2016, 07:26 PM   #5
You just need to crimp on a fork....easy peasey
dabears54
Old 12-14-2016, 07:46 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,252
dabears54
For a general use receptacle, the circuit can't be larger than a 20 amp circuit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
Old 12-14-2016, 08:14 PM   #7
Rewards Points: 87
@dabearsjoe420 - Thanks, yea the wire is 10/3 - Red, white, black, ground.
The appliance says minimum 10amps so a 15a or 20a breaker should be good right?
Old 12-14-2016, 08:35 PM   #8
Licensed electrician
Rewards Points: 3,688
A 15 or 20 amp is fine.
Old 12-14-2016, 09:51 PM   #9
Rewards Points: 534
only thing about #10 it will be hard to push back in. my dad wired his outlets with #10 when i was a little kid.asked why he did it ,he said "i didn't want it to catch fire."
circuitman is offline   Reply With Quote
Old 12-14-2016, 10:24 PM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
Wow..... he connected recepticals to it... he is a strong SOB or has carpel tunnel now....... or has overfilled boxes.....
MTN REMODEL LLC is offline   Reply With Quote
Old 12-15-2016, 10:34 PM   #11
Rewards Points: 534
yeap my dad sure did it in his shop!to boot it was 10-2w/g uf!i'm glad i never had to pull them out!
