DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Can I change a 220v outlet to 120v and use existing 10awg wire (https://www.diychatroom.com/f18/can-i-change-220v-outlet-120v-use-existing-10awg-wire-455321/)
hellonoko 12-14-2016 06:51 PM
I have a dedicated washer/dryer circuit running to my daylight basement.
30amp 220v breaker.
10awg wire.
However my plans are to install an all in one condensing washer/dryer that required a 120v circuit of at least 10amps. (No decent way to vent a regular dryer)
Can I change my outlet and breaker and keep using the 10awg wire?
Or do I need to come off something else in the bathroom that is already 120v?
Everything but the bathroom is enclosed so running a new wire would be pretty rough.
I will be talking to an electrician about this but wanted to get an idea of what I will need to do.
Thanks!
joed 12-14-2016 06:56 PM
Re: Can I change a 220v outlet to 120v and use existing 10awg wire
It would not be against code to use #10 on a 15 or 20 amp circuit. You might need to pigtail some #14 or #12 to get the wire to fit a receptacle properly.
Oso954 12-14-2016 07:05 PM
As a laundry area, the 120v circuit needs to be 20amp and the receptacle must be GFCI protected, if you are in the USA.
dabearsjoe420 12-14-2016 07:24 PM
Absolutely you just can't go any bigger that a 30 amp single pole breaker.....does your existing wire have a ground....aka 10/3
dabears54
dabearsjoe420 12-14-2016 07:26 PM
You just need to crimp on a fork....easy peasey
dabears54
jbfan 12-14-2016 07:46 PM
dabears54
For a general use receptacle, the circuit can't be larger than a 20 amp circuit.
hellonoko 12-14-2016 08:14 PM
@dabearsjoe420 - Thanks, yea the wire is 10/3 - Red, white, black, ground.
The appliance says minimum 10amps so a 15a or 20a breaker should be good right?
Jim Port 12-14-2016 08:35 PM
A 15 or 20 amp is fine.
circuitman 12-14-2016 09:51 PM
only thing about #10 it will be hard to push back in. my dad wired his outlets with #10 when i was a little kid.asked why he did it ,he said "i didn't want it to catch fire.":surprise::surprise::surprise:
MTN REMODEL LLC 12-14-2016 10:24 PM
Wow..... he connected recepticals to it... he is a strong SOB or has carpel tunnel now....... or has overfilled boxes.....:wink2:
circuitman 12-15-2016 10:34 PM
yeap my dad sure did it in his shop!to boot it was 10-2w/g uf!:surprise:i'm glad i never had to pull them out!:vs_mad::vs_mad::vs_mad:
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
