Can This Clamp Be Used With Romex ? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2014, 09:42 AM   #1
Rewards Points: 219
Can this clamp be used with Romex ?
Hello,
I have a silly question ... I'm running new 12AWG in my garage to metal boxes and the clamps are different on some of the receptacle boxes. Some simply push against the cable to keep it place, and others have the clamp in the attached image. Can this be used with ROMEX, or is this for BX only? Thank you
Jim Ignatowski is offline   Reply With Quote
Old 07-03-2014, 06:54 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 896
Nope. AC or MC (BX).
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 07-03-2014, 07:44 PM   #3
Rewards Points: 3,396
Originally Posted by Jim Ignatowski View Post
Hello,
You could trim that clamp with a side cutter or tin snips. Take the clamp out, snip the two pieces that turn into the circles, make sure those snipped pieces are not sharp and hopefully gone. Put it back in the box.
Make it look like this clamp.
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
ront02769 (07-03-2014)
Old 07-03-2014, 08:12 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 896
Return the boxes and get ones with NM clamps.
Any reason you are not using plastic boxes?
Cutting the clamps is a modification of a listed debice. An AHJ could call you on it.
Old 07-03-2014, 09:21 PM   #5
Rewards Points: 219
Thanks, that's what I thought. The container these boxes came out of actually said BX & NM clamps. I stared at those clamps and couldn't figure out how I would thread NM through it. I went back to Home Depot and they let me grab a few of the NM clamps in exchange for those.
The reason for the metal boxes is because it's my garage. Not sure it that's a good reason or not, but the whole house is metal ... and mostly BX, except for what I've been running. Thanks
Old 07-03-2014, 09:35 PM   #6
JUSTA MEMBER
Rewards Points: 3,932
Looks like you have already solved your question.
I just wanted to comment on your name.
I LIKE IT
ed
de-nagorg is online now   Reply With Quote
Old 07-03-2014, 09:47 PM   #7
Rewards Points: 219
I sometimes use Louie DePalma as well :-)
Old 07-03-2014, 09:49 PM   #8
JUSTA MEMBER
Old 07-04-2014, 12:36 PM   #9
Tags
clamp , romex
Cable clamp for 1/2 inch knockout and 10/3 romex? mikegp Electrical 9 02-19-2013 07:32 PM
2 romex in 1 clamp ? Fix'n it Electrical 6 09-03-2012 10:15 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
how many wires through each Romex clamp? Tra Electrical 1 10-04-2010 12:23 PM
Is metallic ceiling box OK for Romex? Ultrarunner2017 Electrical 6 12-04-2009 12:03 PM
