Can A Apartment Duplex's Ground Wire Feed Off The Neighbors Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2015, 12:38 PM   #1
Rewards Points: 101
Can a apartment duplex's ground wire feed off the neighbors ground wire?
I live in a duplex and my main breaker box is grounded. My neighbor's main breaker box (which is right next to my main breaker box) is NOT grounded. Obviously there are two electrical meters, therefore we have our own electrical bill.
Is it legal for them to run a ground wire from my main breaker box to his main breaker box so he will have a ground?
Obviously this is the easiest way to do it since both of the breaker boxes are side by side. That would take minutes to do. The other way is for him to run his own ground wire to his own ground rod. That would take hours.
thanks in advance!!
stanlam is offline   Reply With Quote
Old 12-20-2015, 12:46 PM   #2
Rewards Points: 1,832
Whats wrong with it now?
Jump-start is offline   Reply With Quote
Old 12-20-2015, 12:54 PM   #3
Rewards Points: 101
I guess there is nothing technically wrong with their electrical since it works fine.
However, to answer your question, it's just because their main breaker box is NOT grounded. I think the electrician that put in their breaker box must of forgot to ground their breaker box.
Old 12-20-2015, 01:23 PM   #4
Per code the electrician should have looped the GEC into you neighbors panel, but from a safety and operations standpoint their is really no worry.
Old 12-20-2015, 02:38 PM   #5
Rewards Points: 2,084
thanks in advance!!
I am guessing that there is only one service drop to this house and that is split between two meters. In that case one grounding electrode conductor is all that is needed as long as everything is bonded together. Take the covers off and see if you can follow the grounding conductor.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 12-20-2015, 04:33 PM   #6
ER2
Rewards Points: 70
The only place your system should be grounded is at the service entry point. What makes you think it's not grounded? I assume you mean bonded.
ER2 is offline   Reply With Quote
The Following User Says Thank You to ER2 For This Useful Post:
Jump-start (12-20-2015)
Touching ground wire to metal box trips breaker lmm Electrical 30 07-23-2014 12:36 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
Running new(up to code) ground wire & protection. MikeSF Electrical 25 07-04-2010 04:33 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
