Can Anyone Tell Me What This Is? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2014, 04:52 PM   #1
Angry
Can anyone tell me what this is?
I recently moved into a house where there is a room that used to be a garage with a few outlet covers. This outlet is at the height of a switch, but I can't possibly think of what it could go to. There are two white wires with different colored wires coming out of them. Can anyone help?
Since I need at least one post to post links, I will post the picture in a reply.
Nathan664 is offline   Reply With Quote
Old 08-17-2014, 04:58 PM   #2
Well it's not letting me post a link to the picture, but the original post describes it all. It's at the height of a light switch, but there are only two white wires with multiple colored wires coming out of those. There is still an outside light overlooking the driveway right above where the garage door used to be, but there is no light switch to turn it on.
Old 08-17-2014, 05:01 PM   #3
https://www.dropbox.com/s/2olqi1559f...2010.38.50.jpg
Old 08-17-2014, 05:05 PM   #4
Master Electrician
Rewards Points: 5,378
Telephone cables.
brric is online now   Reply With Quote
The Following 3 Users Say Thank You to brric For This Useful Post:
Know A Little (08-17-2014), mpoulton (08-17-2014), Nathan664 (08-17-2014)
Old 08-17-2014, 06:22 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 3,680
Telephone, or intercom, or something similar.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Msradell (08-17-2014)
Old 08-17-2014, 09:51 PM   #6
dmxtothemax's Avatar
Rewards Points: 7,854
It's definitely low voltage wiring,
telephone most likely,
But could be many other things that only require low voltage
intercoms. speakers for music, alarm systems.
Its no good for mains wiring of any type !
dmxtothemax is offline   Reply With Quote
Old 08-17-2014, 11:44 PM   #7
Rewards Points: 6,652
Telephone.
Old 08-18-2014, 04:32 AM   #8
An old Tradesmen
Rewards Points: 9,516
If their is another box in the ceiling near where a garage door opener would have been. It may be the wires for an old garage door opener.
Old 08-18-2014, 04:20 PM   #9
Rewards Points: 159
My guess, is cable TV conductors without the RJ45 jack.
RocketGal is offline   Reply With Quote
Old 08-18-2014, 04:27 PM   #10
Master Electrician
Your guess is wrong.
The Following User Says Thank You to brric For This Useful Post:
Oso954 (08-18-2014)
Old 08-18-2014, 04:29 PM   #11
JUSTA MEMBER
Rewards Points: 3,992
Looks similar to phone wiring from the late 50s , early 60s. .
Definitely not for any 110 lighting.
Do not use it.
ED
de-nagorg is offline   Reply With Quote
Old 08-18-2014, 04:35 PM   #12
Oso954's Avatar
Rewards Points: 1,910
Wall phone.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
gregzoll (08-18-2014)
Old 08-18-2014, 05:46 PM   #13
Defiantly not !
No good for high frequency.
unless it's cat -5 video.
Old 08-18-2014, 05:55 PM   #14
Master Electrician
Do not use it.
ED
That type of telephone cabling was used well into the 1990's and beyond.
Old 08-18-2014, 06:07 PM   #15
TV does not use RJ-45. That is Cat-3 Telephone wiring. All it is good for, is a telephone jack.
Tags
garage , outlet , switch
