Can 15 A Light Switch Be Used On A 20 A Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 06:41 AM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Originally Posted by jbfan View Post
Why? Do you have 20 amp receptacles?
I doubt that you would ever plug anything in that pulled 15 amps.
I only have one and it's not switched, but if I was to add a switch to it I would find a 20 amp. Though, do they even make 20 amp standard switches? Chances are I would not be drawing more then 15, but it's the principal that matters. It could. If the switch is not rated and could burn up inside, rather not take the chance.
Old 07-22-2010, 06:41 AM   #17
Rewards Points: 2,068
Originally Posted by Red Squirrel View Post
For a light, it is probably safe given the load will never really change, but personally I would not do it. If that switch controls a receptacle, then no way.
Easiest is just change the breaker to 15 amps.
I agree Red my answer was based on the unknown and I cautioned on the safe side because I am not here to actually see what's on the circuit.
A lot of people said many different things which was already a given.
What I know is people leave out a lot of information , not by choice but just by not knowing. I don't know what's on the Op circuit can't see it from here. I will retract my statement for myself only I would use a 15 amp switch at my place, why? because I know what's here. OK let em rip Scuba and the like I am ready to read and hang my head. When in doubt follow manufacturer's instructions.
COLDIRON is offline   Reply With Quote
Old 07-22-2010, 06:45 AM   #18
Just call me Andrew
Rewards Points: 1,032
But it doesn't matter what's on the rest of the circuit...only what's being controlled by that switch.
Andrew
secutanudu is offline   Reply With Quote
Old 07-22-2010, 06:50 AM   #19
What if an 20 amp outlet was on the switch leg and a air conditioner was a 20 amp plug and drew over 15 amps ?
Old 07-22-2010, 07:06 AM   #20
Wire Chewer
Rewards Points: 528
Oh yeah if there's just a light controlled by that switch then you'd be safe enough. I meant if there is a receptacle controlled by it too, then you can never predict what could be plugged in there in the future.
Old 07-22-2010, 07:31 AM   #21
Just call me Andrew
Right - the OP said only a single light will be controlled by this switch.
The only potential issue I see is a short from black to white may pull more than 15 amps for a brief moment. That being said, I'd use the 15A switch.
Andrew
Old 07-22-2010, 08:31 AM   #22
I've never seen anyone plug an AC into a outlet & turn it off & on by a switch
But I'm sure its possible
We aren't dealing with What if's
We are dealing with a single light
Possible someone could add for a total of 1800w+ of lights in the future
Also possible someone could add a switched outlet to the switch
This is not much different then a 15a/20a pass thru receptacle
Its more likely & possible to put a surge suppressor plugged into a single 15a receptacle & draw more then 15a then it is to overload a single light
And drawing more then 15a thru a single 15a receptacle probably happens more often
So are you recommending everyone replace their 15a receptacles with 20a to avoid any possible problems ?
Old 07-22-2010, 08:34 AM   #23
Licensed electrician
Rewards Points: 3,660
Even the 15 amp receptacles are rated for 20 amp feed through.
Old 07-22-2010, 11:51 AM   #24
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Old 07-22-2010, 12:18 PM   #25
Originally Posted by speedy petey View Post
that's cool speedy.
Old 07-22-2010, 03:29 PM   #26
Electrician
Proby's Avatar
He would have a cooler house.
Proby is offline   Reply With Quote
Old 07-22-2010, 04:42 PM   #27
Just call me Andrew
The a/c couldnt be a 20-amp plug unless you had a 20-amp outlet...which is not allowed on a 15A circuit.
Andrew
3-way switch circuit w/light on each end. rcraighead Electrical 6 06-01-2010 10:57 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
