California Law & 220v Outlet Install - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 04:46 PM   #1
California law & 220v outlet install
Hi..I have alittle dilemma I am trying to work out..
I have a brand spankin new 220v cabinet table saw I need to hook up. I plan on putting it in an attached 2nd garage, which is located about 75' from the main electrical panel off the ouside of the main garage. I am going to run conduit out to this garage for the 220. It's a pretty straight foward run ( I just have to drill through 2 stucco walls...bleah) I do have to run the outside length of conduit under a flower bed, because putting galvanized conduit up on the wall and running that way isn't going to asthetically fly with me, or more importantly, my wife!
So my question is what sort of codes am i lookign at that I need to meet? Do I need an inspection?
TIA!
arminyack is offline   Reply With Quote
Old 08-03-2009, 05:24 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Why are you using galvanized steel? Why not use PVC?
Old 08-03-2009, 06:29 PM   #3
I am, actually...I dont knwo why I said galvanized. Brain, fart or smeothing
Old 08-03-2009, 07:58 PM   #4
Issue of using Galvanized or PVC for outside (UG) run
Never mind the Brain. What about (straining) the Muscles of your arms, lifting and bending the pipe?! (No matter what) Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
flat screen tv outlet stang93 Electrical 9 12-20-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 08:22 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
