Cable Wire Add On - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 04:19 PM   #1
Cable Wire Add on
Have a chance for a steal of a deal (about 1/3 the price) for #2 Aluminum cable that is supposedly direct burial. I was looking to use such for a feeder line to a sub panel in a barn however, it would be short and would need to extend.
As I was planning on encasing in conduit anyway (due to other issues here), can this cable be SAFELY added on to by one of those little extender items that you put cable in each side and each as a set screw to tighten down? if so, what is the additional prep needed? some kind of sealer or heat tape or something like electrical tape?
May not make sense in the long run but would hate to pass up deal if safely and properly doable.
thoughts?
MeanGene is offline   Reply With Quote
Old 06-26-2010, 09:32 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 986
A splice must be inside an approved box and accessible
A splice can not be made inside the conduit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 06-28-2010, 08:47 AM   #3
thanks....and that is understood. my question was more along the lines of can it screw down type of connectors be used? if not, what can be used for #2 cable splicing;
Old 06-28-2010, 01:22 PM   #4
jbfan's Avatar
Rewards Points: 986
Any kind of approved method.
Split bolts, polaris connectors are two that come to mind.
They must be approved to handle AL wire.
The Following User Says Thank You to jbfan For This Useful Post:
MeanGene (06-28-2010)
Replacing my 150 amp wire to 200 amp due to bad cable loosewire Electrical 6 12-21-2009 04:52 PM
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 04:31 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
fault in old bx 2 wire cable switch loop scire Electrical 1 10-25-2009 01:16 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
