Cable Type - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2014, 08:11 PM   #1
Rewards Points: 512
Cable Type
Hey guys, it's been awhile.
60-100amp upgrade on a garage. What can I use between meter base and panel? I'm thinking I need 4 wires, so 2-2-4-6 SER? This will be a Main, not a Sub panel.
I'm using USE from weather head to meter base 2-2-4.
I do need 4 wires, don't I, between the meter and panel?
Installation is the Reverse of Removal.
Old 09-10-2014, 08:41 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,442
Main breaker panel only requires 3 wire, so SEU.
SER is used when 4 wires are needed, such as after a main disconnect at the meter.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
sirsparksalot (09-11-2014)
Wall Oven Whip Cable Type traffic_ahead Electrical 2 11-20-2012 09:02 AM
I need to test a cable for a kitchen range justplumducky Electrical 4 10-21-2012 11:23 PM
Burying Coax Cable Master Brian Electrical 4 08-07-2011 02:21 PM
plastic bushings for MC cable amakarevic Electrical 11 05-16-2011 07:56 AM
What type of cable to install for a whole house rewire? brons2 Home Theater 27 03-07-2010 07:36 AM
