Buzzing Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 11:40 AM   #1
RDS
Rewards Points: 150
Buzzing switch
My bathroom has a single recessed light over the tub and a three-bulb fixture over the vanity. (Also a ceiling light in the middle of the room and an exhaust fan.) All are on separate switches on the same circuit. Nothing else is on the circuit.
When the light over the tub and vanity light are on at the same time, they both flicker and there's a loud buzzing sound from the switch.
When each is on individually, they work fine. No other combination of switches being on causes any problem.
Experimentally, I changed the bulbs in the vanity fixture from 100W incandescents to 13W CFLs. The problem was still there.
All the wiring was done with new cable, new everything by a licensed electrician and approved by an inspector about a month ago. The problem has only emerged in the past week.
What's likely to be the cause of this problem? What should I do about it? I know I could call the electrician back but I know it'd be at least two weeks before he showed up. I have only minimal experience working with electrical but if there's a simple fix I'd rather tackle it myself and get it resolved quickly and without paying the guy again.
Thanks for any guidance.
RDS is offline   Reply With Quote
Old 09-30-2009, 01:34 PM   #2
check to see that all connections are tight also is the light flourescent
mike242424 is offline   Reply With Quote
Old 09-30-2009, 01:46 PM   #3
RDS
Rewards Points: 150
Thanks for the reply, Mike.
No, the light over the tub is not fluorescent -- just a regular 60W incandescent. As mentioned, the problem is there whether I put incandescents or CFLs in the vanity fixture.
I will remove the switch plate and take a look. I assume what I'd be looking for is any wires that pull out of the wire nuts if I give them a little tug? (Yes, I'll turn off power to the circuit first.) Or is there a better way to check for connections that aren't tight?
Seems weird that a loose connection wouldn't cause flickering if only one fixture is turned on. (As mentioned, I get the flicker and buzz only when both are turned on.)
Thanks.
Old 10-01-2009, 06:29 AM   #4
RDS: Try another switch. First try bridging over the switch terminals with test lead and observe operation. Sometimes the mechanical innards of switches and circuit breakers may loosen enough to vibrate and with more current, more buzz. I suspect that the switch contacts are arcing, thus causing the lights to flicker.
oilseal is offline   Reply With Quote
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Dimmer switch buzzing billyg Electrical 8 01-24-2008 08:02 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
