Buzzing Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 11:03 PM   #1
Rewards Points: 518
Buzzing noise
I'm looking at buying a condo that was built in 2006. They used a Siemens sub panel within the suite. I've noticed that the AFCI breaker for the bedrooms making a buzzing noise when turned on. If I turn on a high draw appliance like the range oven with all 4 burners on, the AFCI makes an increased audible humming/buzzing that intermittently cuts out. Is this normal for this brand? I have moderate residental electrical experience and have installed Cutler Hammer AFCI's without anything noticeable. If I reset it the sound sometimes goes away. A quick google seach for siemens afci buzzing turned up many results with varied opinions, most of which say its "normal".
Also, when I metered the voltage I was getting between 113-115V at any receptacle in the suite. I'm used to seeing 120-122V. Not sure if this is an issue as well.
n0c7 is offline   Reply With Quote
Old 01-16-2010, 12:32 AM   #2
Rewards Points: 518
I'm going to make an offer on this place tomorrow and asking for one of the conditions be subject to repairs. Any takers on what might be the cause or if you've seen these issues?
Honeywell Thermostat Buzzing kbuckle Electrical 13 03-11-2017 01:15 PM
Water baseboards generating clicking noise Dezso3 Plumbing 1 01-15-2010 07:13 AM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 08:38 AM
