Buzzing Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 02:31 AM   #1
buzzing lights
My sister has just moved into a house with an outdoor play area. It's a concrete slab surrounded by chain link fencing and covered by a sloping wooden roof. There is a regular light switch at the entrance attached to wiring that connects to two plain light fixtures. When turned on they buzz. At least, my memory tells me it's the lights, but maybe it's the switch itself. It is a very loud buzzing - kinda scary! What could be causing this? I have done no testing on it (such as changing out the lightbulbs or checking connections), but I was hoping you could give me a place to start. Sorry to be so vague! Thanks!
SaladGoat is offline   Reply With Quote
Old 01-12-2012, 03:28 AM   #2
Julius793's Avatar
What kind of fixture? Sound like a ballast problem, try replacing it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-12-2012, 04:02 AM   #3
dmxtothemax's Avatar
Rewards Points: 7,824
Are you sure they are regular lights ?
To me regular means incandesant !
But if they are floro or any other type of discharge light,
then they would have a ballast (a type of transformer) !
these can come loose, and buzz.
Usually tightening them up will solve the problem,
If not you will have to replace them.
dmxtothemax is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Lights Flickering, Dimming, Brightening, and Buzzing OldManJim62 Electrical 23 01-13-2012 10:19 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
