Buzz Buzz Goes The J Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 12:58 PM   #1
buzz buzz goes the j box
Hi there,
New to the fourm, but looking for some answers/clues, here is the issue
I moved into a home that has an out building that was completely wired and has its own fuse box and all. It looks like a good install and everything seems to be in order.
Inside the home there is a switch that is at a door that goes to the back yard and when I turn it on, it doesnt do anything.... except buzz in a j box under the house! I dont want to undo all the conections yet as I am not sure where they lead. There looks to be a lead heading twards the out building and maybe to some lights (along a out door path)that dont work.
So my question is, can I test this line at the out building when the switch is on and see if there is power there with some sort of line tester or a remote tester?? If so, what is one of those devices called?
Also, as far as the buzzing that I get when the switch is on, is this a hot wire to ground? or hot touching the box maybe?
Is all of this too much for a DYIer with some electrical savy or should I call out THE MAN on this one?
Thanks,
Woton
woton121 is offline   Reply With Quote
Old 11-04-2011, 07:40 PM   #2
Rewards Points: 3,032
What is in the junction box?
A loose connection can give off a soft buzz.
A transformer such as for a doorbell can buzz.
Maybe there is a buzzer (or bell whose clapper doesn't hit properly) inside.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 11-04-2011, 08:21 PM   #3
Have you looked under the house while it is buzzing?
Maybe there is an outlet down there and someone left something plugged in?
Billy_Bob is offline   Reply With Quote
doorbell buzz troubleshoot HELP bergerdude Electrical 17 05-14-2013 05:20 PM
GFCI outlet - buzz noise cfreak Electrical 2 10-18-2011 12:26 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
A/C Transformer buzz - high pitched sound ComfortSD HVAC 5 12-27-2008 01:37 PM
How to avoid audible buzz with dimmer switch wkend3 Electrical 4 08-27-2008 09:44 PM
