Bulbs Stop Working Quickly - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 02:03 AM   #1
Rewards Points: 215
bulbs stop working quickly
I have a ceiling light fixture in my entry hall that is just a couple years old. It uses four 25 watt clear globe bulbs. Lately, I'll replace the bulbs in a couple of the sockets and they stop working again within a week. I'm wondering what might be causing this? Thanks in advance for any advice.
bucksone is offline   Reply With Quote
Old 06-08-2010, 05:45 AM   #2
Bulbs not seated tightly on the contacts. Sometimes due to the bulb length, sometimes due to the cardboard cover over the socket. Another possibility is a bad connection at the wires, but all lights would probably go out if that were the case.
Old 06-08-2010, 05:50 AM   #3
Master Electrician
Rewards Points: 5,082
Vibration, overvoltage.
brric is online now   Reply With Quote
Old 06-08-2010, 06:08 AM   #4
Retired Moderator
Rewards Points: 7,174
Add to the vibration and over voltage---Bad batch of bulbs---It happens.
Old 06-08-2010, 07:00 AM   #5
Rewards Points: 2,800
Can you tell if the filaments are broken?
Failure with the filament still intact could be due to insufficient seating in the socket resulting in overheating and melting of a contact down there.
Low wattage 120 volt incandescents (under 30 watts) have very thin filaments that are more sensitive to vibration.
With the breaker turned off you may be able to reach into the socket with a bent paper clip and raise the bottom contact a bit to get better seating of the lamp (bulb).
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 06-08-2010, 08:16 PM   #6
Union Electrician
goose134's Avatar
Go to an electrical supply house and ask for rough service bulbs. The filaments are made to really get beat up. We had to use them in MRI rooms because the magnet made the filaments bounce like crazy. Knocked out around 30 lamps in 4 days.
goose134 is offline   Reply With Quote
Old 06-08-2010, 08:22 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Maybe they are producing too much heat, just for fun, try a few CFLs. Maybe start with just one. You could also check the voltage at the socket to see if it's way above 120. It's tricky to get the electrodes in the socket and can be a hazard if you slip and cause a short, so you could get one of those "bulbs" that turns a socket into a plug, then put the electrodes in the plug to test.
Old 06-08-2010, 09:19 PM   #8
Union Electrician
goose134's Avatar
Actually I hadn't thought about that. Overvoltage might cause bulbs to burn out. I know they make bulbs that are rated for 130volts.
Old 06-08-2010, 10:19 PM   #9
Wire Chewer
Rewards Points: 528
Yeah it's usually the first thing I check as it's easy, but could be all the other things too. I was thinking maybe even overheating, if it's an enclosed fixture.
Halogen track lighting quit working Dialogdog Electrical 4 02-08-2010 09:20 PM
flourescent bulbs keep popping. darsunt Electrical 12 02-06-2010 10:10 AM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 08:10 AM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 02:34 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
