Bulb / Lamp Ceiling Receptacle With Odd Device Attached - Electrical - DIY Chatroom Home Improvement Forum
Like Tree10Likes
  • 4 Post By BRodgers
  • 3 Post By Solonious
  • 1 Post By Msradell
  • 1 Post By joed
  • 1 Post By Solonious
Old 09-17-2018, 09:16 PM   #1
Bulb / lamp ceiling receptacle with odd device attached
Greetings.. Was hoping someone can tell me what in the world is attached to this receptacle. It is actually emitting a buzzing noise. Any help would be great before I replace it and end up electrocuted somehow!
Bulb / lamp ceiling receptacle with odd device attached-20180917_215123_1537236916990.jpg   Bulb / lamp ceiling receptacle with odd device attached-20180917_215128_1537236946259.jpg
Solonious is offline   Reply With Quote
Old 09-17-2018, 09:18 PM   #2
Rewards Points: 56
Re: Bulb / lamp ceiling receptacle with odd device attached
That is your doorbell transformer.
SPS-1, Msradell, de-nagorg and 1 others like this.
BRodgers is offline   Reply With Quote
Old 09-17-2018, 09:26 PM   #3
Aha! Odd that my doorbell is half way across the house from this location..and my doorbell does not work. So this is just converting to DC? I can unhook and go with a wireless doorbell instead of troubleshooting a 40 year old doorbell. Thanks very much for your help!
Msradell, de-nagorg and Nealtw like this.
Old 09-17-2018, 10:03 PM   #4
Msradell's Avatar
Rewards Points: 1,012
At least you can find your transformer, ours went bad and I have no idea where it is? I've looked in all the obvious places and it's not there.
SPS-1 likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 09-17-2018, 10:06 PM   #5
Rewards Points: 56
It outputs 24 volts AC. Feel free to disconnect and go with a wireless doorbell if you want to.
Old 09-17-2018, 10:23 PM   #6
Rewards Points: 2
You might learn that at one time a deaf person lived there and the door bell dims the light instead of having a chime. Unless Iím wrong.
Dixiedevil is offline   Reply With Quote
Old 09-17-2018, 10:31 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 30,936
Anything is possible but that is just a normal doorbell transformer.
Dixiedevil likes this.
The Following User Says Thank You to joed For This Useful Post:
Dixiedevil (09-18-2018)
Old 09-18-2018, 06:25 AM   #8
Rewards Points: 9,826
Is the transformer very warm ? If it humming and very warm, it could very well be that the contacts on your door bell switch are simply stuck closed.
SPS-1 is offline   Reply With Quote
Old 09-18-2018, 11:43 AM   #9
That's a great idea actually. Thank you for the suggestion I'll give it a try.
Oso954 likes this.
Old 09-18-2018, 11:49 AM   #10
Rewards Points: 2
It has to be/been connected to a chime or something somewhere. Curiosity would have me running it down. The transformer has to have a connection for a signal device.
Iím thinking about a new doorbell but I put a $300 Nest thermostat that wants me to be 74 degrees and I want to be 71. The better Ring doorbell is $250-$500.
Old 09-18-2018, 01:11 PM   #11
Yes it's connected to a chime. Well I assume it is. The wire runs in that direction. I haven't messed with the chime yet. Just moved in a few months ago so checking off projects as time permits. We use a nest cam as our baby monitor. Are you saying nest makes a doorbell system as well that might tie in? I'll have to check that out.. Thanks in advance.
Old 09-18-2018, 02:10 PM   #12
Super Moderator
joed's Avatar
Nest makes the Nest Hello video door bell.
https://nest.com/ca/doorbell/nest-hello/overview/
Bulb/fixture that hides ceiling imperfections stripedbass Electrical 16 01-08-2017 01:49 PM
Rewiring a switch controlled receptacle to a ceiling light. machine_hed Electrical 7 09-03-2015 09:36 AM
splitting a ceiling lamp into two circuits bruce_hyman Electrical 11 06-04-2012 05:21 AM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Converting a ceiling lamp holder to a grounded outlet koz Electrical 2 12-30-2009 06:24 AM
