Bulb Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2019, 01:53 PM   #1
Rewards Points: 56
Bulb issues
Bought this fan from HD Few years ago, no matter what bulb i put in it they flicker, and i have a controller for the light.
When it's in Max they almost give a mild burning smell!
Too low and flickering gets worse.
What type of bulb is suited for these?
I've tried CFL, LED....
thx
miserkris1 is offline   Reply With Quote
Old 05-05-2019, 02:43 PM   #2
Rewards Points: 2,598
Re: Bulb issues
thx
My first guess would be an issue with the controller. Some of those older ones are not cfl/led friendly. It's possible something could be going bad with the light kit but not likely. However, if so, they are easy to replace.
jmon is online now   Reply With Quote
Old 05-06-2019, 12:42 AM   #3
dmxtothemax's Avatar
Rewards Points: 7,680
Re: Bulb issues
Does it flicker with an incandesant lamp in it ?
Maybe it is not compatible with with LED or CFL.
Otherwise I would say either the watt limiter is faulty
Or the control circuitry is faulty
either one should be available as a spare part.
dmxtothemax is offline   Reply With Quote
Old 05-08-2019, 06:30 PM   #4
Rewards Points: 56
Re: Bulb issues
Haven't tried incandescent bulbs...
I have 3 of those fans in 3 rooms they behave same, installed in 2012....
LEDs were in market in 2012 right?
Thx
Old 05-08-2019, 08:53 PM   #5
Rewards Points: 58
True, some controllers are not designed for LED. Also, not all LED bulbs are dimmable.
Wiredindallas is offline   Reply With Quote
Old 05-08-2019, 09:24 PM   #6
Rewards Points: 1,718
Re: Bulb issues
And many dimmable LEDs work better with some brands/models of dimmers than they do with others.
It's such as mess that Lutron has a web page to match up specific LEDs that are known to work with their dimmers.
RAL238 is offline   Reply With Quote
Old 05-09-2019, 10:02 AM   #7
Rewards Points: 1,886
Re: Bulb issues
Also, some dimmable controllers do not work with LED bulbs, even if the bulbs claim to be dimmable.
huesmann is offline   Reply With Quote
Stove "Range Hood" can light new bulb - not enough room with my hands to twist it on HTFreak Electrical 6 07-13-2016 12:36 PM
Wet bulb / dry bulb DOUG1111 HVAC 15 03-07-2016 09:16 PM
Cold walls, humidity issues, frost issues with exterior doors Howitzer Insulation 46 12-14-2014 10:56 AM
CFL issues sjpoolowner Electrical 6 11-14-2010 06:15 PM
