Building A Lamp (Threaded Rod IPS Question) - Electrical - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 12-25-2018, 05:56 PM   #1
jb9
Rewards Points: 196
Building a Lamp (Threaded Rod IPS Question)
Hello,
I am building a steampunk style wall sconce and I need to connect a small section of threaded hollow rod (1/8" IPS) to a reducer bushing (1/2" x ___). I am leaving the previous dimension blank because I don't know what to get. The threaded hollow rod has threads 1/8" IPS and a 3/8" OD. Do I get the reducer bushing that is 1/2" x 1/8" OR 1/2" x 3/8"? In these fixtures, this is the transition from the piping to the electrical components.
Here is an example of a similar fixture:
https://www.etsy.com/listing/2623876...elated-7&frs=1
Thanks.
jb9 is offline   Reply With Quote
Old 12-25-2018, 07:24 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 2,100
Re: Building a Lamp (Threaded Rod IPS Question)
What do you need the 1/8" for. I have built these and used only 1/2" Iron Pipe and reducers and flange. Just curious.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 12-25-2018, 08:36 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 22,536
You need 1/8 ips to 1/2 ips.
Old 12-25-2018, 08:42 PM   #4
Naildriver
chandler48's Avatar
Oops, forgot about the yoke. Yes, but I believe it is 1/4" in the yoke. 1/8" may be too small to pass zip cord through.
Larry......
Old 12-25-2018, 08:44 PM   #5
Master Electrician
Rewards Points: 4,874
IPS threads are not compatible with NPT iron pipe threads. IPS threads are straight threads while NPT are tapered threads. You need a bushing to convert 1/2" NPT(the iron pipe) to 3/8" IPS threads.
You might be able to use a 1/2" NPT to 1/8" NPT bushing and secure the 1/8" IPS pipe to the bushing with IPS nuts to the bushing. 1/8" NPT has an O.D. of .405 inches.
brric is online now   Reply With Quote
Old 12-25-2018, 08:57 PM   #6
Rewards Points: 70
Since it's doesn't need to hold fluids and not structural, it might be just fine. I think the threads are close enough to mate, but won't seal very well. My memory could be wrong though.
Cheers!
Bondo and ChuckTin like this.
supers05 is offline   Reply With Quote
Old 12-26-2018, 12:28 AM   #7
jb9
Rewards Points: 196
I have attached a close up picture of the result I am seeking. The yellow line represents the 1/8 IPS threaded rod that I know is under the lid. I just don't know what the reducer bushing fitting is. I am fairly certain the socket accepts 1/8 IPS so I know there is a 1/8 IPS rod under there. The rod is screwed into the mystery bushing and the lid is sandwiched between the bushing and the socket.
I just don't know what the specs of the bushing is...
I may just head to the hardware store and take a section of 1/8 IPS rod (male) and see if I can find a pipe reducer bushing and see what NPS female thread will accept it. Does that sound reasonable?
Old 12-26-2018, 12:40 AM   #8
retired framer
Rewards Points: 12,172
If the black pipe is 1/2"
https://www.universalair.com/1-2-Mal...05-bf12-23.htm
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
jb9 (12-26-2018)
Old 12-26-2018, 12:44 AM   #9
jb9
Rewards Points: 196
Thanks Neal. Or this?
https://www.supplyhouse.com/Bluefin-...-Black-Bushing
I think the spec which reads "malleable iron" is interesting... Maybe the male IPS threads will mate to the female.
Old 12-26-2018, 01:57 AM   #10
Rewards Points: 70
That's just another name for black iron.
It'll likely mate, but it won't thread all the way. Probably enough to keep things together.
Cheers!
Bondo likes this.
The Following User Says Thank You to supers05 For This Useful Post:
jb9 (12-26-2018)
Old 12-26-2018, 02:21 AM   #11
retired framer
The thread is the same but the npt thread is tapered, it will work.
supers05 likes this.
jb9 (12-26-2018)
Old 12-26-2018, 04:23 PM   #12
jb9
Rewards Points: 196
I just got back from the hardware store and you guys were right.
The threaded rod does fit into the bushing but it only threads on about 2 revolutions. The taper does start to impede the threading. I also learned from a friend, that a 3/8-27 tap will clean up the threads on the bushing to perhaps allow the threaded rod to get a little more thread engagement.
I didn't actually find the 1/2x1/8 bushing but I did find a 1/8 thread female brass coupler but I am confident that I can get these fittings to mate in a way that will be secure. The globe on the fixture + the socket parts won't be too heavy I hope but I won't resume the assembly until I'm confident the electrical components are securely connected.
Old 12-26-2018, 04:43 PM   #13
Rewards Points: 70
2 threads will hold a dozen lbs or so.
Cheers!
Old 12-26-2018, 04:49 PM   #14
retired framer
I have done it and they went in more than that but you could tap them out easy enough. I repaired a chandler with brass fittings,
Old 12-26-2018, 06:16 PM   #15
Rewards Points: 56
I have also done it with my steampunk 'rocket fighter' and yes, it works fine but I added a tiny bit of blue locktight just to sure it up a little.
Toolmaker68 is offline   Reply With Quote
Small building floor concrete question VaBob Concrete, Stone & Masonry 5 09-20-2016 08:22 PM
One last question before I start installing walls in block building pointer80 Building & Construction 4 05-30-2015 06:09 AM
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
direct burial/conduit question entering building wombosi Electrical 8 06-01-2009 11:33 PM
