Broken Wire In Wall? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2015, 08:10 AM   #16
Rewards Points: 48
Murphy"s law at work again. A receptical which is not used because it is behind
a large book case loaded with books which had to be moved for access. Couldn't be an easy outlet Yup Murph is at work again.
Also, with anything you have lost or misplaced you always find it in the last place you look!!!!!
Glad you found it.
bernie
bernie963 is offline   Reply With Quote
Old 01-07-2015, 11:53 AM   #17
Rewards Points: 794
That's because you stop looking when you found it. The English language, aren't you glad you learned it when you were a kid...
B
Beepster is offline   Reply With Quote
Tags
broken wire? , lost power
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-20-2016 11:30 PM
solder broken 12GA wire under concrete steps. photomikey Electrical 5 10-16-2011 12:44 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
Radiant Ceiling heat wire...how to fix broken wire? Cmik HVAC 1 10-20-2010 02:42 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
