Broken Outdoor Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2014, 04:19 PM   #1
Rewards Points: 20
Broken outdoor junction box
Before I go ahead and replace this junction box I want to make sure I'm going about this correctly and not missing anything.
I have an outdoor junction box that is broken:
The metal bit highlighted here was chipped off so the outlet won't stay back (technical terms):
I picked up a "Master Electrician, Single Gang Outlet Box, With 3 1/2" holes" at the store.
On the inside of the current box 18.3 CU. IN. is printed. Im not sure what that means or if it's important.
blg002 is offline   Reply With Quote
Old 09-22-2014, 04:37 PM   #2
Licensed electrician
Rewards Points: 3,766
Boxes are sized to allow proper spacing for conductors. The cubic inches tells you how many conductors and devices you can put in the box.
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Making a patio from broken granit slabs need help BJLower Tiling, ceramics, marble 9 09-15-2014 12:15 PM
Cracks and broken pieces. stangn99 Concrete, Stone & Masonry 1 05-26-2014 10:59 AM
Broken window glass replacement miamicuse Windows and Doors 4 05-23-2014 09:19 AM
