Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 02:10 PM   #1
Breaker Panel
I have an older home the none of my outlets have a ground. How would I go about running ne outlets with out a complete remodel?
MJMeier is offline   Reply With Quote
Old 12-14-2010, 06:49 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 24,022
Install GFCI. Label them Non grounded.
Old 12-14-2010, 09:28 PM   #3
Rewards Points: 262
You can use GFCI receptacles with "un-grounded" labels, but that's not a perfect solution. Surge suppressors for electronics require a ground to provide protection, and some high-current 120V appliances are not suited for the sensitivity of GFCI outlets (refrigerators/freezers, for example). I would consider the GFCI option as a stopgap until the house wiring can be upgraded, but not as a permanent solution.
clashley is offline   Reply With Quote
Old 12-15-2010, 11:43 AM   #4
Licensed electrician
Rewards Points: 3,662
Freezers and refrigerators should have no problem running on GFI protected circuits.
The code does however require that certain appliances like refrigerators, freezers, air conditioners, washers, dishwashers ... be used with grounded circuits. The complete list is in Article 250.114.
Old 12-15-2010, 12:44 PM   #5
Rewards Points: 262
The requirements for grounded appliances aside, I dislike putting food-storage appliances on GFCIs due to the potentials for nuisance trips. Nothing like coming home from a week's vacation to a box of spoiled food because of a nuisance trip.
Old 12-15-2010, 12:53 PM   #6
I would rather come home to the very unlikely chance of spoiled food than to find someone dead from a ground fault.
On a side note, refrigerators in commercial kitchens are required to be GFI protected.
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
Do you think I should keep this breaker panel? fetzer85 Electrical 19 03-12-2010 06:11 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Slot #3 blocked in Q0N Breaker Panel dallen Electrical 5 11-05-2007 06:37 PM
