Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 12:32 PM   #1
breaker panel
I have a 200 amp outdoor boxunder meter and am now going to install a 200 amp indoors with all the breakers. I have two locations in mind. one would have a dryer in front of panel the other is straight up on the second floor. Are either or both okay
JohnSmith is offline   Reply With Quote
Old 08-03-2010, 12:41 PM   #2
Just call me Andrew
Rewards Points: 1,032
Check out this picture in the Scuba_Dave's sticky:
http://www.diychatroom.com/f18/nec-n...47/#post430750
Andrew
secutanudu is offline   Reply With Quote
Old 08-03-2010, 12:44 PM   #3
Electrician
Proby's Avatar
Are you still going to have an outside disconnect?
What room would it be in on the second floor?
I've seen long debates about putting a dryer in front of the electrical panel. When you are making an installation, you never know where a homeowner is going to move their stuff later down the road
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-03-2010, 12:45 PM   #4
this means behind the dryer is not so good, Is the second story okay
Old 08-03-2010, 12:48 PM   #5
outside panel is build into the meter and only hold a few breakers, the big one of course is the main shut off. I have a garage on a sub panel. The house is small but need the 200 amp so either it goes upstairs or a few fee up a wall with plumbing in it??
Old 08-03-2010, 12:50 PM   #6
Oh and second story is just one room like a loft
Old 08-03-2010, 12:52 PM   #7
Electrician
Proby's Avatar
Does it have a closet and window?
Ok, so you are going to have the main disconnect outside still, correct? If so, you can run a cable thru the basement and put the panel where ever you want.
The Following User Says Thank You to Proby For This Useful Post:
JohnSmith (08-03-2010)
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
Do you think I should keep this breaker panel? fetzer85 Electrical 19 03-12-2010 06:11 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Slot #3 blocked in Q0N Breaker Panel dallen Electrical 5 11-05-2007 06:37 PM
