Breaker Keeps Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2015, 02:23 PM   #1
Rewards Points: 4
Breaker keeps tripping
No idea if this is the right spot... please move if inappropriate. Thanks!
The kitchen light switch has been making a weird noise, kind of a clicking noise when we hit it for a while now. Also on the same breaker is the bathroom and part of the basement. Previously, the breaker only tripped when we had a lot going and a hair dryer.
Anyway, now, every time we hit the kitchen light switch, it trips the breaker. If we turn on the basement or bathroom light, it's fine. We replaced the kitchen switch, it keeps happening.
It is immediately as soon as you turn on the light.
The switch is new, the light fixture is less than a year old.
No leaks anywhere as far as we know.
Is this a breaker problem, fixture problem or.... ?
Thanks for any info!
Leashy is offline   Reply With Quote
Old 08-18-2015, 02:43 PM   #2
Rewards Points: 107
I will bet it's a short between your light switch and the fixture or perhaps in the fixture itself . The breaker is doing its job.
jimn01 is offline   Reply With Quote
Old 08-18-2015, 02:52 PM   #3
Rewards Points: 5,348
Try replacing the breaker.
They go bad.
If the new breaker trips, leave it off and troubleshoot the circuit.
Ron
B. Franklin 1759
Old 08-18-2015, 02:57 PM   #4
Oso954's Avatar
Rewards Points: 2,136
+1 for the light fixture/wiring.
Bad breaker would trip on the last load added, not just kitchen light.
Oso954 is online now   Reply With Quote
Old 08-18-2015, 05:04 PM   #5
Rewards Points: 4
What does it mean (if anything) if you take out the bulb and it still does it? Only asking because someone said if there's no bulb, electricity shouldn't be going to it and if it still trips, it's not the fixture.
Oy.
Old 08-19-2015, 05:29 AM   #6
Rewards Points: 6,236
It's a dead short somewhere, the fixture is the easiest to check, but first make sure the new switch is wired correctly.
Entering your general location can help with answering a lot of times
Old 08-19-2015, 06:47 AM   #7
Rewards Points: 7,111
Check the connection inside the last box you worked on before the problem started. It is very easy to accidentally create a loose connection or short that is activated by the movement of the switch.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 08-19-2015, 06:50 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
What kind of breaker?
Is it a gfci, or afci breaker?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 08-19-2015, 06:54 AM   #9
jbfan's Avatar
Rewards Points: 946
Mods, this should be moved to the electrical forum.
Old 08-19-2015, 06:58 AM   #10
Retired Moderator
Rewards Points: 7,174
Moved to electrical---note---use the red ! report button when you see a thread in the wrong forum.
jbfan (08-19-2015)
Heat Pump Help! Swapped Contactor, now tripping breaker!!! trifecta50 HVAC 74 02-13-2015 09:00 AM
AFCI breaker tripping in laundry room esahlin Electrical 11 11-27-2014 07:40 AM
One breaker tripping another armisjam Electrical 12 03-09-2012 08:43 PM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 06:47 PM
Tripping Wrong Breaker [email protected] Electrical 15 03-28-2008 01:47 PM
