Branch Circuit Breaker Specification - Electrical - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 3 Post By chandler48
  • 1 Post By jbfan
  • 1 Post By chandler48
  • 2 Post By Shadow99
  • 1 Post By Oso954
  • 1 Post By rjniles
Old 11-11-2017, 05:02 AM   #1
Rewards Points: 368
Branch circuit breaker specification
All products are linked below. I've taken pictures of both my load center and the circuit breaker. I'm going to have this work done by a certified electrician. This post is for learning purposes only.
I have several computers that will be plugging into a PDU. This PDU then plugs into a L6-30R. This L6-30R will connect to a double pole 240V AC 30 amp branch circuit breaker. Following AWG guideline, I will need a 10 gauge wire. I've already gotten the circuit breaker. What is confusing to me is that on the label of the circuit breaker for AWG, it's being labeled as "14-6".
What does "14-6" have to do with 10 gauge wire? What does "14-6" suppose to mean? The 6 in "14-6" suppose to mean 6 connection points. 3 at the receptacle, 2 at the circuit breaker, and 1 at the load panel? What does 14 suppose to specify?
I didn't happen to get the wrong circuit breaker did I? If I am not reading this label correctly, is there a link/website that I can read up on to learn how to read circuit breaker specification?
Thanks.
circuit breaker album: https://imgur.com/a/4AyzY
circuit breaker: https://www.homedepot.com/p/Siemens-...?keyword=q230u
PDU: https://www.tripplite.com/5.8kw-sing...taa~PDUMH30HV/
L6-30R: http://www.leviton.com/en/products/2620
Load center album: https://imgur.com/a/FvFHd
AWD guideline: https://en.wikipedia.org/wiki/American_wire_gauge
012abc is offline   Reply With Quote
Old 11-11-2017, 05:15 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,428
Re: Branch circuit breaker specification
The 14-6 indicates the smallest wire the screw pressure plate can accept and the 6 indicates the largest that will go in the hole. You match your wire to the load and breaker size. 10 gauge is correct.
jbfan, CodeMatters and Blue Marjan like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
012abc (11-12-2017)
Old 11-11-2017, 10:26 AM   #3
Rewards Points: 368
Ahh, so it's a range! Thanks for the clarification.
Old 11-11-2017, 09:29 PM   #4
Rewards Points: 368
I have another question if you don't mind. If 10 gauge wire is the correct size for this amp, what's the point of having a breaker support wire from 14 gauge all the way up to 6 gauge?
What are the advantages and disadvantages of going to a 14 gauge wire on a 30 amp breaker? Would going to a thinner 14 gauge wire be dangerous, since the thinner wire can only support up to 25 amp?
What are the advantages and disadvantages of going to a 6 gauge wire on a 30 amp breaker? Future proofing? In the case that you might need higher amp in the future, there's no need to re-do the wiring? Beside the fact that it is more difficult to work on thicker wire, there are no disadvantages?
Old 11-11-2017, 10:03 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,758
In some cases it is code compliant to install #14 or #12 on a 30 amp breaker.
Using #8 or #6 would be compliant for a voltage drop issue or requirement.
J. V. likes this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
012abc (11-12-2017)
Old 11-12-2017, 05:04 AM   #6
Naildriver
chandler48's Avatar
Remember, too this is mass production. I would venture to guess all breakers from one manufacturer come with the same basic casing and connection points. Only the guts are changed to match the needed amperage. Saves money and time to make the breakers to where they will accept a range of wire sizes.
CodeMatters likes this.
Larry......
Old 11-12-2017, 07:35 AM   #7
Super Moderator
joed's Avatar
Rewards Points: 31,904
A 30 amp breaker is not limited to #10 wire. There are circumstances where different size wires need to be used. One example would be for extra long runs where you need to upsize the wire to avoid voltage drop.
Old 11-12-2017, 08:16 AM   #8
Rewards Points: 368
Ahh I see. So about how long in feet does the wire need to be before it needs to be up size?
Old 11-12-2017, 08:19 AM   #9
Rewards Points: 368
Would you mind giving a real world example of when it would be necessary to use a smaller wire (#14, or #12) on a 30 amp breaker?
Old 11-12-2017, 10:51 AM   #10
Deleted Member
Shadow99's Avatar
Rewards Points: 1,080
Motor circuits. Breaker is upsized for inrush on startup.
jbfan and Blue Marjan like this.
Shadow99 is offline   Reply With Quote
Old 11-13-2017, 04:13 AM   #11
Ever Learning
Blue Marjan's Avatar
Rewards Points: 316
there was a discussion on another thread (I've forgotten which) about installing sub-panels, and whether to install the same size breaker at each end, and Codes and inspector preferences and so on ... I have a Service Panel which feeds sub-panels in other bldgs, and have smaller breakers in the sub-panels than in the service panel, specifically so that the sub-panel will trip first. The breaker in the service panel protects the wire, which for cost considerations I bought in bulk and all the under-ground in-conduit wires are the same size, but most of my sub-panels have smaller breakers. My inspector was fine with that.
Blue Marjan is offline   Reply With Quote
Old 11-13-2017, 11:21 AM   #12
Oso954's Avatar
Rewards Points: 1,808
So, how many times has one of those sub-panel's breakers actually tripped first and saved a walk ?
jbfan likes this.
Oso954 is online now   Reply With Quote
Old 11-13-2017, 11:39 AM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 880
The breaker in a sub panel is a disconnect and can be any size, smaller, larger or the same as the feeder breaker in the main. The sub having smaller breaker than the main is no guarantee it will trip before the main. A dead short will cause hundreds of amps to flow, which trips first depends on which one reacts the fastest.
Blue Marjan likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Oso954 (11-13-2017)
Old 11-14-2017, 04:35 AM   #14
Ever Learning
Rewards Points: 316
Depends who is working tools ... not EXPECTING the dead short problem unless something goes wrong, but the smaller breaker is because SOME people get involved in their work and plug in too many tools at once.
Water Dripping From Circuit Breaker Box/Frayed Service Line Magnetic Electrical 6 02-03-2014 03:50 PM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 08:15 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
