Box Installation For Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2010, 07:42 PM   #1
Question
Box installation for Ceiling Fan
Hi. For a ceiling fan, can the appropriate box be installed by attaching to the side of one joist? Or should it be attached using an over the joist type box, or intstall another joist parrallel to the existing joist and attaching the box on both sides. Or what other ways. I have a box installed now (former owner) that did not have anything in it, just a cap. I want to put a ceiling fan in, but the box is just attached on one side to a joist.
Thanks for your suggestions.
Stuart
staylor is offline   Reply With Quote
Old 04-24-2010, 07:48 PM   #2
Master Electrician
Rewards Points: 5,082
Some fan rated boxes attach to the side of the joist.
brric is online now   Reply With Quote
Old 04-24-2010, 07:50 PM   #3
Fans over 35# need a special bracket.
Old 04-25-2010, 08:18 AM   #4
Licensed electrician
Rewards Points: 3,660
Determining the type of fan support to install depends on where the joist is in relation to the fan location. Boxes are made to fit the situation.
Here is an example of a screw on old work fan box that can install next to a joist.
http://www.smartboxinc.com/electrical_boxes.php#RND
You can also find a similar style in metal for use with metallic cables.
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
