Blown Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 03:36 AM   #1
Blown breaker
Hi there so I have run a 6/3 wire with a ground wire from my 50 amp panel hot tub breaker box to feed an 8 circuit sub panel in my shed. I disconnected the hot tub & put a non PVC junction box in the hot tub enclosure.
My sub panel has: 1-single pole amp Breaker 120v circuit,1-20amp 240 volt circuit, 1-15 amp 240 circuit.
I have a ground plate hooked to the equipment ground bar in the sub panel. When I energized the sub panel my 120 circuit worked fine, it has about 8 amps on it.
When I used my 20 amp 240 volt circuit the 50 amp breaker in the hot tub box tripped. Any ideas......
MajorReno is offline   Reply With Quote
Old 08-01-2010, 06:09 AM   #2
Rewards Points: 1,192
I would say not enough watts!
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
walkerj (08-01-2010)
Old 08-01-2010, 07:38 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I am still confused as to what the heck is going on here.
Are you using an old hot tub feed for a sub panel?
Are you using the new panel along wit the hot tub?
Where are the main panel, "hot tub panel", and the new panel located?
What is a non-PVC junction box, and where is it?
I suspect the 50A breaker for the tub is a GFI and IT is causing the trip.
Old 08-01-2010, 07:38 AM   #4
I=E/R
a7ecorsair's Avatar
Since you have a meter to measure AC current,
you should be able to find the cause. Is the hot tub still being used - you said you disconnected it?
a7ecorsair is offline   Reply With Quote
Old 08-01-2010, 02:24 PM   #5
Oh sorry more info... Setting up wifey's glass shop or possible living quarters for teenage son not likely more like for me to get away from them Ah the perfect size to work on my car...if I could just get it in the back yard. Anyways there is an existing shed about seventy five feet from the main house with a hot tub set up in between. The hot tub works great it's just that we don't use it. So yes I'm using the Hot tub feed & it's a new 100 amp panel in the shed . The distance from the main panel to the GFCI panel box is about 20' from there to the hot tub is about 35', from the non "grounded" pvc junction box, (which I placed inside the hot tub enclosure) to the shed is about 40'. Your right that is the breaker that keeps tripping and I haven't even fired up her kilns yet. As the hot tub will be drained & not used again until we get the bigger main panel replaced I figured I could use that power to the shed for now. Can I replace the GFCI at the hot tub panel box/spa pack box with a reg breaker and place the GFCI receptacles outside on the shed? that way there still working down that line?
Thank you
Old 08-01-2010, 02:40 PM   #6
Master Electrician
to start with your running a new hundered amp panel off a 50 amp hot tub feed. The list of code violations is about 10 miles long on this one. Run a new wire from the main panel and save yourself a fire.
andrew79 is offline   Reply With Quote
Old 08-01-2010, 02:52 PM   #7
Electrician
Proby's Avatar
That's fine here. It's hard to find sub-panels that are rated under 100A.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-01-2010, 03:32 PM   #8
" Euro " electrician
frenchelectrican's Avatar
What ya running on 20 A 240 volt circuit ? and did you get the wiring hook up correct ?
The way I can see there are a issue or two came up due you mention non pvc box and did you double check the conductors for any nicks or cuts that can trip the breaker?
Merci.
Marc
Old 08-01-2010, 08:09 PM   #9
For a 17amp 240 volt kiln.
Here are some pics of what I've done.
Blown breaker-6.-over-hot-tub-juction-box.jpg   Blown breaker-7.-under-ground-until-here.jpg   Blown breaker-8.along-fence-back-under-ground.jpg   Blown breaker-9.-back-up-shed.jpg   Blown breaker-10.-ground-plate-wire.jpg
Old 08-01-2010, 08:13 PM   #10
With the power off, confirm the line to line or line to ground short with an ohmmeter and then disconnect wiring sections until you isolate the short.
Old 08-01-2010, 08:15 PM   #11
Is that a green grounding screw on the top bar in the sub ?
Grounding the neutral bar to the case/ground ?
Old 08-01-2010, 08:17 PM   #12
Do I see NM cable in underground conduit?
romexican is offline   Reply With Quote
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
20-amp breaker blown? L_duffy01 Electrical 3 04-25-2008 09:26 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
