Big Spark From Hot Feeder When Install A Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 10:09 PM   #1
Smile
big spark from hot feeder when install a water heater
i installed more then 10 water heater with no problem before until this one, i think everything was normal, but at the moment i turned the breaker on, then a big spark happened just like an explosion (big sound and spark). The hot feeder was beated up at 1 inche away from the connection between the heater's black wire and the black feeder. But the breaker did not trip. I dont know what caused that?
maittai1 is offline   Reply With Quote
Old 07-27-2010, 06:57 AM   #2
Rewards Points: 2,800
You probably had two wires accidentally touching. INsulation may have been worn away allowing the bare wire to touch something else. Also it is easy for stranded ends of a wire to poke over to the next screw or to other metal parts. Do you have a picture of exactly where the spark happened?
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
The Following User Says Thank You to AllanJ For This Useful Post:
maittai1 (08-08-2010)
Old 08-08-2010, 10:28 PM   #3
thanks, i dont have a picture of these wires but i already had an electrician come over to check it out and he said the same thing.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
