Best Way To Go About Installing Sconces On Each Side Of Garage [outside]. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2009, 12:07 PM   #1
Rewards Points: 226
Best way to go about installing sconces on each side of garage [outside].
I've got 2 wall sconces that I'd like to install on each side of the garage. My garage is finished so I'd have to fish them thru to the location and my house is stucco.
My question is:
Do I need to install one of those junction boxes? It seems like that would be a lot of work to cut out the cement stucco to put on in there.
Any other recommendations is helpful.
imola ghost is offline   Reply With Quote
Old 11-06-2009, 02:23 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,676
Without a junction box, how would you wire and mount the light?
The lights need a box to mount to and a place for the wire connections.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 11-06-2009, 02:28 PM   #3
A lot of times people use pancake junction boxes - 6 cu inches
Ask your local Inspector if they will accept that
Alternate is finding a light where it is rated as a junction box
Old 11-06-2009, 02:43 PM   #4
Rewards Points: 226
I guess just cutting out some stucco might not be too bad but I'd better be sure that these sconces are the one's I want! LOL.
Old 11-06-2009, 02:48 PM   #5
300zx's Avatar
Post
put one of these on each side and run one wire to each one and o j-box in attic
300zx is offline   Reply With Quote
Old 11-06-2009, 02:48 PM   #6
300zx's Avatar
Post
Scuba dave beat me to it
Old 11-06-2009, 05:50 PM   #7
Well....if that seems like a lot of work, you are not ready to do this project. Cutting the stucco is one of the easier parts.
When we add garage lights we take power from the garage door opener recep, run conduit on the inside and punch thru the wall because the exterior walls are tough to access at this point unless it's a gable end.
Long sentance^
You need jboxes at each fixture. They type of box depends on the framing/construction. Sometimes a pan box is called for, other times it's a bad choice. Also, someone will surely chime in about box fill on a pan box but pay them no mind
Your switch is a whole nother issue. Find fixtures with built in photo cells and save some grief.
Better yet, call someone
220/221 is offline   Reply With Quote
Old 11-08-2009, 04:25 PM   #8
Isn't a pan box rated for 14-2 for an outside light?
2 hots & a ground = 6 cu inches = pan box
12-2 would be 6.75 cu inches whioch would exceed the rating of a pan box....but only by a little
I didn't think the wires for the light count ?
hmmmmmmmmmm
410.10 Space for Conductors. (old code section )
Canopies and outlet boxes taken together shall provide adequate space so that luminaire (fixture) conductors and their connecting devices can be properly installed
Old 11-08-2009, 05:23 PM   #9
I was thinking of the first box with a cable in and out.
Not that that would stop me.
Old 11-08-2009, 05:45 PM   #10
Ah....true - he wants to connect 2 sconces
Old 11-08-2009, 05:54 PM   #11
300zx's Avatar
Post
you could run one wire in each and put a j-box in the attic
Old 11-08-2009, 07:31 PM   #12
Rewards Points: 226
I finished the project on Saturday and used the 3" pancake box that was recommended here.
Thanks for the help.
Old 11-08-2009, 07:52 PM   #13
Thumbs up
Additionally. the connection needs to be protected against arcing (sparking) (as in Spark Plug); (No matter what) don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Installing service to my garage. WFKnight Electrical 4 02-27-2009 10:18 AM
Some questions about installing new garage door on old opener and other stuff Skeletor916 General DIY Discussions 2 01-23-2009 04:51 PM
Installing an attic above my 2 car garage jdavid Carpentry 2 07-17-2008 11:50 AM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Installing garage door ??? coltsfan Remodeling 5 08-11-2006 01:59 AM
