Bedroom Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2015, 01:19 AM   #1
Rewards Points: 225
bedroom wiring
Have two bedrooms adjoining each other. Each bedroom would have approx 4 outlets. One ceiling fan/light in the one bedroom. The other room would have two recessed lights. No ac unit currently but may install later. Trying to decide how to wire the rooms. One 20 amp circuit for the receptacles in both rooms and one 15 amp circuit for the fan and lights? Or if each room had an ac unit run 2 20 amp separate circuits? A/C around 12 amps leaves minimum 4 amps for the other receptacles in each room. Use 3 20 amp circuits and have the lights/ fan circuit connected to one receptacle for the ac in one room an the other ac in the other room connected to the other 20 amp circuit? Thanks for any advice.
gt1935 is offline   Reply With Quote
Old 09-03-2015, 09:23 AM   #2
Rewards Points: 168
one 20 amp should be fine for all the plugs and lights in both rooms, even a 15 would probably be fine, unless you plan on using something heavy duty like a space heater,
run a dedicated line/circuit for each a/c unit
Mikey1 is offline   Reply With Quote
Old 09-04-2015, 09:31 AM   #3
Rewards Points: 780
OK, I will be the one to ask: is the project being done under a permit?
For what reason are you wiring two bedrooms? Is this an addition? Are you rehabbing these two bedrooms?
It's one thing to add wiring you may need in the future (for the ACs) if the walls are open, but another to add it if you are fishing wires through closed walls.
You could probably get everything on one 15A cicuit if it serves only these two bedrooms.
Don't forget tamper resistant outlets and AFCI breakers.
B
Beepster is offline   Reply With Quote
Old 09-04-2015, 06:35 PM   #4
Rewards Points: 299
I'd do a 20 amp circuit for each bedroom, including the a/c unit. The lights should have their own circuit so they do not dim when the a/c compressor kicks on.
Syberia is offline   Reply With Quote
Old 09-05-2015, 07:39 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Even with the lights on the same 20A circuit, with such a small load the lights will almost certainly not dim due to this one circuit.
The Following User Says Thank You to Speedy Petey For This Useful Post:
brric (09-05-2015)
Old 09-05-2015, 07:44 AM   #6
First off, a newer A/C that is a 12A draw is in the 12-15K BTU range. That is HUGE for an average bedroom.
More likely you will have a 6-8K BTU for a BR.
Old 09-06-2015, 01:14 AM   #7
Rewards Points: 299
I have an 8k in my office. Right on the nameplate on the compressor, the LRA (start-up load) is listed as 35 amps. That will dim lights on a 20A circuit.
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 07:33 AM
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Anyone decipher this bathroom wiring? schnitz411 Electrical 8 08-08-2010 03:21 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
