Bedroom Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 12:33 PM   #1
Question
Hey im about to wire up a bedroom ive got the main feed coming in and was wondering where i should run it to? I plan on putting the lights on the same circuit. It is canadian so i am running #14. Also can this all be done in a 2 wire ?
john457 is offline   Reply With Quote
Old 03-20-2010, 12:55 PM   #2
Just call me Andrew
Rewards Points: 1,032
If you're using #14 wire, the breaker has to be 15A. It can all be done in 2-wire unless you wand independent switches for a light/ceiling fan (if you have one).
Is there anything else on this circuit?
Is the incoming feed near where you want the light switch to be?
Andrew
secutanudu is offline   Reply With Quote
Old 03-20-2010, 01:12 PM   #3
The feed is going exactly to where i want the switch to be. Should i feed the switch and what connections are going to be in that box? I know all about the breakers and strapping and supporting codes i just want to make sure im feeding the proper thing and doing everything in the right order. The circuit is just going to be about 6 receptacles and a light.
If i need a piece of 3 wire where will it go to and from and what connection is made?
Old 03-20-2010, 01:30 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Don't qoute me wrong but IIRC one of the two Canada providices start requried the AFCI in the bedroom circuits I know in BC area do and Ontario do required.
So therefore check with your local inspector or permite office for the latest info.
Merci, Marc
Old 03-20-2010, 01:32 PM   #5
I'm pretty sure it does. Im just wondering about the wiring for now though. I haven't made the panel connection i just have the wire from the panel room to the bedroom.
Old 03-20-2010, 01:47 PM   #6
Ahh ok John .,
for the feed to the light switch you can bring the feed to the light switch then after that one cable go to the recetpales the other cable that can go to the light { if you plan to run the ceiling fan it will be best to bring the 14/3 cable so you can able run the fan and light sepearted in case you do not have remote controller }
In the switch box all the white conductors you can wirenut then you have to know which black conductor is from the breaker box { the feed to the switch box } take that black conductor and the other black conductor for receptale and wirenutted with pigtail so you can able hook up the switch.
now the last black conductor that go to the light that will be on the switch { in case if you have red that will be used if have fan in there }
BTW make sure you use the deep well junction box { at least 21 or 22 Cu inches }
But if you want to use one switch for light and second switch for fan then I really suggest to get two gang switch box it will be easier to deal with it.
Merci,Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
john457 (03-20-2010)
Old 03-20-2010, 01:51 PM   #7
That was perfect thanks alot ! If anyone would like to add anything go for it.
Old 03-20-2010, 02:01 PM   #8
Let me add one more thing along the way the bare ground conductor of course that will be wirenutted as well and leave a pigtail{s} as well for the switch{s}
Merci,Marc
Old 03-20-2010, 02:03 PM   #9
I understand grounding but what do you mean about the pigtail? Im obviously going to have 3 grounds at the switch you just mean twist 2 of them together so i can get them all under the screws?
Old 03-20-2010, 02:09 PM   #10
John ,
Here the example of pigtail look like .,,
Hope that clear up how it done with it.
Merci,Marc
Old 03-20-2010, 02:24 PM   #11
Alright yeah that cleared it up i thought you meant where i had my 3 grounds at the switch. Thats good thanks alot.
Old 03-20-2010, 02:27 PM   #12
I am glad to give you a helping hand and if you have any other issue come up let us know one of us will be more than happy to reply to ya.
Merci,Marc
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Beautiful Bedroom Renovation! EdinDesign Project Showcase 11 10-03-2008 01:40 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
your guestimation and or opinion on removing a bedroom shan Remodeling 2 12-09-2005 03:46 PM
