Bathroom Vanity Light Installation Advice - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 08-17-2016, 05:50 PM   #16
Rewards Points: 6
Re: Bathroom vanity light installation advice
Cut and replace drywall is what I usually end up doing
sync3 is offline   Reply With Quote
Old 08-17-2016, 06:31 PM   #17
Rewards Points: 14
Originally Posted by Oso954 View Post
It's hard to be sure of things based upon the photo. But the apparent height of the backsplash and setting of the mirror so close to it, makes me wonder if there was a facelift to that bathroom prior to the OP moving in.
Depending on the actual heights of things, a vanity light box could be behind the mirror.
I feel like a complete idiot, but you're absolutely right. It never even occurred to me to look behind the mirror. After I took it off to try and trace the wires from the switch there was the electrical box with all the wires neatly tucked in. It does look like the mirror was hung up a little too high. Oh well, at least no more mystery.
Thanks again everyone, and sorry to waste your time.
firehawkmph and lenaitch like this.
yyanpolski is offline   Reply With Quote
The Following 3 Users Say Thank You to yyanpolski For This Useful Post:
Jim Port (08-17-2016), NickTheGreat (08-18-2016), Oso954 (08-18-2016)
Old 08-18-2016, 09:46 AM   #18
Rewards Points: 34
Don't apologize for wasting time - I read this thread and found it insightful.
jdsmn21 is offline   Reply With Quote
Old 08-18-2016, 09:59 AM   #19
Rewards Points: 4,544
Your problem got solved, I don't think anyone feels like their time was wasted.
stick\shift is offline   Reply With Quote
Old 08-18-2016, 10:40 AM   #20
Knows Enough to be Danger
Rewards Points: 1,295
What an anti-climatic thread. No code violations. No hidden copy of the Constitution. Nothing.
Glad you got it figured out. Make sure to post a follow up picture when you put the lights up
NickTheGreat is offline   Reply With Quote
Old 08-18-2016, 11:16 AM   #21
Oso954's Avatar
Rewards Points: 1,274
Not a waste of time, it is what we are here for.
Thanks for letting us know the how things worked out.
Oso954 is offline   Reply With Quote
Old 08-21-2016, 08:41 AM   #22
Rewards Points: 14
Wanted to follow up. It seems to me the most obvious way to proceed would be to move the electrical box up. Someone suggested that another way might to use a plastic wire channel/tube from the fixture to the box, and still connect all the wires inside the box. Possibly cutting out a path for the tube in the drywall as well. If I don't mind the appearance of the channel itself, would something like this be a safe way to do this? Thanks
Old 08-21-2016, 09:17 AM   #23
Licensed electrician
Rewards Points: 3,740
You could move the box up if there is enough cable or depending on the fixture just add a short cable in the wall using the old box as a junction.
yyanpolski (08-21-2016)
New bathroom vanity installation igneous Carpentry 5 05-23-2016 01:40 PM
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
Light installation billathome65 Electrical 1 12-04-2013 12:30 AM
bathroom vanity light height above mirror amakarevic Interior Decorating 6 03-22-2012 04:02 PM
bathroom vanity light fixture hook up maggie3707 Electrical 5 02-26-2012 11:22 PM
