Bathroom Receptical - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 04:35 PM   #1
bathroom receptical
can I go from the load side of a gfci to wire a new receptical?
acanna1 is offline   Reply With Quote
Old 11-24-2010, 04:53 PM   #2
Yes u can
heartlessmcfly is offline   Reply With Quote
Old 11-24-2010, 04:55 PM   #3
Rewards Points: 2,800
Yes.
Note that the circuit must be 20 amps (12 gauge) and serve either receptacles-only in one r more bathrooms, or receptacles and lights and fan etc. all in one bathroom. (No lights or receptacles in other rooms.)
So a typical use might be a GFCI receptacle in one bathroom and from the load terminals you feed a receptacle in another bathroom.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 11-25-2010, 01:09 PM   #4
I forgot to mention that in the bathroom there are already two recepticale.....I just want to add one more for convienance sake? The GFCI is right next to where I want to put the extra receptacale, so I thought that would be ok......the actual toilet is closed of and it has an exhuast fan and light combo and two switches one for the fan and one for the light......the receptical I want is where the vanities are so we don't have to have a cord across the floor for my wifes TV! I know, I know....but it's for the "WIFE!" I really appreciate the help....since I'm in the learning mode!!
Old 11-26-2010, 10:19 AM   #5
Electrical Supplier
Rewards Points: 150
Yes you can wire it like you describe.
LyonsElecSupply is offline   Reply With Quote
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 05:24 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
