Bathroom Receptacle Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 01:32 AM   #1
bathroom receptacle circuit
Can someone clarify the code regarding bathroom receptacles. i am in the process of rewiring a two bath ~900 sq ft house. The design has a general lighting circuit that includes bathrooms and other rooms. The recepaticle circuit for the bathrooms will have GFCI at the panel, but i am wondering if i can also put a receptacle in the laundry room off the same (GFCI) circuit serving the two bathrooms.
Thanks for your expertise, Steve
Steve Burke is offline   Reply With Quote
Old 07-15-2010, 04:34 AM   #2
Rewards Points: 1,192
No! Laundry rooms 1 circuit. Bathrooms ! circuit.(each).
bobelectric is offline   Reply With Quote
Old 07-15-2010, 05:42 AM   #3
Licensed electrician
Rewards Points: 3,662
The receptacle circuit can be shared between the two bathroom as long as it is only for receptacles.
Old 07-15-2010, 04:35 PM   #4
Electrician
Rewards Points: 910
I stand corrected, I should have looked it up before answering. Thanks for correcting me joed.
darren is offline   Reply With Quote
Old 07-15-2010, 04:59 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 24,000
No you can't. In Canada the laundry room receptacle circuit must be for laundry room receptacles only. Bathrooms can however share with other circuit except kitchen counter.
Old 07-15-2010, 06:15 PM   #6
many thanks. i will keep Bathrooms on one circuit, laundry on the other.
Regarding the laundry room, i have an electric washer and a gas dryer. Can i have the dedicated, 20A laundry room circuit supply both a general use receptacle (in the laundry room) and the washer (and nominally the gas dryer)?
Old 07-15-2010, 06:52 PM   #7
Laundry room circuit can supply all outlets in the laundry room
It can't leave the laundry room area
As long as there is enough power it can power the washer & gas dryer
My washer uses 7a+
Old 07-15-2010, 07:37 PM   #8
excellent help by you all, now off to finish it up. thanks a bunch!
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
20 Amp Bathroom Circuit theatretch85 Electrical 3 04-06-2009 09:33 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
