Bathroom Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 12:46 PM   #1
bathroom outlet
why did my bathroom outlet go out? Can outlet go bad?
Sharon54 is offline   Reply With Quote
Old 11-11-2010, 01:32 PM   #2
Chicago, IL
Michael Thomas's Avatar
Is a a GFCI outlet:
With a reset button?
If so, have you attempted to reset it by pushing reset the button?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-11-2010, 01:45 PM   #3
Rewards Points: 256
If your outlet is gfci, the first post should fix it. If your outlet isn't, then you should replace it with a gfci outlet anyway.
And yes, outlets and switches go bad: espicially if you buy the ones that cost less then fifty cents.
It is current code to have bathroom outlets gfci protected, but it is possible to have gfci brear and not need the special outlet. This case isn't likeley unless your home is new.
michaelcherr is offline   Reply With Quote
Old 11-11-2010, 02:47 PM   #4
Retired Moderator
Rewards Points: 7,174
Your outlet may be controlled by a gcfi breaker--Go look in your breaker box--see if any of your breakers have a little blue or red push button--If so--push it to reset.
Old 11-12-2010, 11:44 AM   #5
It is also possible that your outlet is downstream of a gfci outlet that needs to be reset.
SleepyDog is offline   Reply With Quote
Non-working outlet... cdc3jj Electrical 11 08-07-2010 08:37 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Bathroom problem Imreced Electrical 6 12-09-2007 11:04 AM
outlet in bathroom cabinet OK? matty Electrical 5 08-02-2007 09:56 PM
