BATHROOM Door Jamb Activated Music-HELP - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2009, 08:21 PM   #1
Hello, I am remodeling a bathroom that is as basically in my kitchen. Whatever goes on in the bathroom is heard in the kitchen. I am trying to figure out a way to activate music when the door is closed. I know that there are switches that turn the lights on when the door is opened. Edwards - Door Jamb Switch EDW502A. Any ideas how I can accomplish my goal by using this switch or in another way? Thanks so much for your help.
8under8 is offline   Reply With Quote
Old 11-24-2009, 09:38 PM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
You're going to need a relay of sorts that closes the circuit when the door closes and energizes the receptacle that the radio is plugged into. I have to tell you though that this is one of the most ridiculous requests I've ever encountered.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 11-24-2009, 09:49 PM   #3
I have a radio in the bathroom, On/off is right on top
If we have a cook-out/party I leave it on
Is it a solid wood door ?
Old 11-24-2009, 10:06 PM   #4
300zx's Avatar
Post
Have you Thought about Motion Activated on a little radio You would want to make sure you are GFCI PROTECTED?http://www.sensorplug.com/
300zx is offline   Reply With Quote
Old 11-25-2009, 04:29 AM   #5
For anyone who thinks this is ridiculous, you're invited for Thanksgiving dinner. When you use the bathroom, you will be 4' from the guests sitting at the center island and 7' from those at the table. And, think about what you'll be hearing when you're trying to enjoy your meal.
Old 11-25-2009, 06:27 AM   #6
Rewards Points: 79
If you are re-modeling why not insulate, use 5/8 Sheetrock and a install solid door? If you really want the radio why not just add a switched outlet that comes on with the light?
Tmb9862 is offline   Reply With Quote
Old 11-25-2009, 11:46 AM   #7
Occupancy sensor...
(Used to switch on lights in public restrooms.)
http://www.smarthome.com/2522W/Levit...150-1LW/p.aspx
Billy_Bob is offline   Reply With Quote
Old 11-25-2009, 01:14 PM   #8
Magnettica's Avatar
Rewards Points: 150
No thanks I already have plans. But the other guys are right. Either leave the radio on or insulate the walls and double the sheetrock. Yours isn't the first bathroom to be near an eating area.
Good luck and Happy Thanksgiving.
Old 11-26-2009, 12:34 AM   #9
I think it's a great idea. I have thought about the same thing for my house and my cabin.
If you are entertaining, just leave it on. Otherwise, a recep controlled by a motion sensor would be easy.
Or stick a playing card into the exhaust fan.
220/221 is offline   Reply With Quote
Old 11-26-2009, 05:58 AM   #10
Rewards Points: 1,174
Maybe even a white noise generator. That way, you don't have to worry about what kind of music the radio is playing. But if you want music, I suggest a CD instead of the radio, and make it hard rock / grunge, or rap.
Bathroom sounds won't be masked by most classical music, or a talk radio show.
If you could find music that everyone enjoys, why not just leave it playing. At least, that's a temporary solution before you get a chance to wire up a switch.
Maybe a loud fan would work. The bathroom could probably use an exhaust fan anyway. If the fan is moving enough air, it might be noisy enough to mask the unpleasant noises.
I used to eat lunch at a restaurant that had a small restroom right off the eating area. It was very unpleasant to have to sit next to the door, so I fully understand your problem.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 11-26-2009, 07:40 AM   #11
Retired Moderator
Rewards Points: 7,174
I had a customer ask me to install a really cheap,noisy exhaust fan in a powder room,once ------
Her girl friends player cards in the room next to it---She wanted-Cover noise--!!!!!!!!!!!!!
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
