Basement Pull Chain Light Fixture Recommendation Wanted. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2015, 12:49 PM   #1
Rewards Points: 38
I have three pull chain light sockets (the ones that include an outlet) in my basement that seem to need constant replacing due to the switch failing (usually jams). I've purchased various brands such as Cooper or Leviton, in both plastic and porcelain.
Has anyone had any luck with durability with these types of fixtures? If so, what brand do you recommend? If switch failure is an inherent problem with these types of fixtures, is there another option that you could suggest?
Thanks in advance for any ideas on this.
kc27 is offline   Reply With Quote
Old 01-23-2015, 01:04 PM   #2
Rewards Points: 4,280
Buy an 8 pack of 13W replaces 60 W fluorescent bulbs for about 9 bucks. Pull the chain and leave them on. In my experience they'll last about 5 months.
Old 01-23-2015, 01:22 PM   #3
Licensed electrician
Rewards Points: 3,740
Add a simple toggle switch to the wall instead of the pull chains. Some rewiring would be needed, but it is relatively simple.
Old 01-26-2015, 09:17 AM   #4
Rewards Points: 38
Thanks for the suggestions. It sounds like there is no such thing as a durable pull chain switch. I'll have to look into the toggle switch option.
I do make use of fluorescent bulbs elsewhere in the house, but for this portion of the basement, I burn 200 watt clear incandescent bulbs for maximum light output. I had looked into the fluorescent equivalent of a 200 watt incandescent bulb, but those bulbs are at least 3 times as long as the 200 watt incandescent bulb. They would hang down too low, putting them in head striking range.
Old 01-26-2015, 09:25 AM   #5
Rewards Points: 127
It might be the heat from those 200 watt bulbs. The pull chains in my basement are for the most part 50 years old. But then again they were made in the USA and probably better built than the current junk.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
SeniorSitizen (01-26-2015)
Old 01-26-2015, 02:18 PM   #6
Oso954's Avatar
Rewards Points: 1,274
Most of those fixtures are rated at 600W, so I doubt it is the heat.
A lot of them fail early because of jerking the chain too hard, rather than a gentle pull.
Oso954 is offline   Reply With Quote
Old 01-29-2015, 01:27 AM   #7
Rewards Points: 38
Wiring in a wall switch is probably going to be the best way for me to go. I am replacing one or more of these fixtures every 18 months, and it doesn't look like there are more durable options for this type of fixture.. The 200 watt bulbs sometimes get left on, so a wall switch with a motion sensor auto off and on would probably be the best solution for me. Thanks everyone for the ideas and advice.
Tags
basement , fixture , light , pull-chain , switch
Adding rocker switch to a light fixture RerunsBuns Electrical 4 07-28-2014 01:27 AM
Ceiling fan light pull chain Mary H Garvey Electrical 0 10-11-2011 02:39 PM
shop light conversion from pull chain to light switch gilbo Electrical 6 03-16-2010 10:49 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
