Baseboard Heater With Built In Thermostat? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2016, 06:36 PM   #16
Bob Sanders's Avatar
Rewards Points: 2,536
Originally Posted by mrssp View Post
They're back-up heat. Our heat pump is efficient up to -25 C, and it rarely gets that cold here in Nova Scotia. Usually, it hovers around 0 C all winter, occasionally dipping to -10 C.
I'm not at all concerned about whether it will accurately sense the temperature.
I have a heat pump with both electric furnace and baseboard heat back up.... but it's all tied into the main thermostat.
All the baseboard heaters are connected to one sub panel in the basement which is controlled by a relay contactor. When the main thermostat senses backup is needed it supplies power to both the furnace contactor and the baseboard heat contactor and it controls the house temperature as normal.
Bob Sanders is offline   Reply With Quote
Old 02-11-2016, 06:40 PM   #17
That's the American site which does not have the same things as the Canadian. I'm not sure, but I think that Cadet thermostat will work on the Likewise heater... it looks like I can mount it on.
I think this one has to have a hole punched in the side... not sure if it will work: https://www.homedepot.ca/en/home/p.b...000120270.html
That's all Home Depot Canada has.
Home depot (Canada) stocks and sells the thermostat controls (separately) for most of the baseboard heaters they supply. You will find them on the shelf right beside the baseboard heaters. At least that's the way it is at my HD
Old 02-15-2016, 06:16 PM   #18
Rewards Points: 1,568
there are some wall heater with programmable thermostat also
carmusic is offline   Reply With Quote
Old 02-15-2016, 06:37 PM   #19
Rewards Points: 86
I ended up paying more for some Dimplex and bought their compatible built in thermostats to install into the heater. Still cheaper than the linear proportional ones, though.
mrssp is offline   Reply With Quote
Electric Baseboard Convection Heater - Buying House Info? olimits7 HVAC 4 10-24-2012 09:45 AM
baseboard heater wireless thermostat hohadcr Electrical 4 08-05-2011 06:06 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 05:28 PM
fan / baseboard heater question deepstuff Electrical 6 10-03-2009 02:09 PM
