Backstabbed Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2019, 08:02 PM   #1
Usually Confused
lenaitch's Avatar
Rewards Points: 2,028
Backstabbed Switch
I was at our daughter's changing out a switch and noticed it was backstabbed; however, there were no release slots so I ended up cutting the conductors.
I later noticed on the back of the switch that "push in terminals not for reuse". It looks like they are kinda-sorta acknowledging that it is a less-than-ideal connection method.
I checked their website (Hubbell, sold under their Bryant line) but could find any further information.
No question - just an observation. Our house was also backstabbed and I have been re-connecting room-by-room as I re-decorate. If the kid wanted to re-wire their devices they would have to cut them all off and buy new.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
de-nagorg (05-30-2019)
Old 05-30-2019, 09:05 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,762
Re: Backstabbed Switch
Most anything that has a wire inserted into a spring connector should not be reused anyway. What happens is you reverse the action of the spring metal and it doesn't hold the wire tight anymore.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 05-31-2019, 05:03 AM   #3
retired painter
Rewards Points: 1,926
I can't think of a good reason to reuse a back stab device. As a diyer I thought they were great when they first came out .... until I realized the small contact point made them prone to failure later on. Locally, they no longer sell backstabs.
mark sr is online now   Reply With Quote
Old 05-31-2019, 07:05 AM   #4
Rewards Points: 1,140
I like to use Eaton Tamper and Weather Resistant devices. I use them in my own houses and structures. They are more of a commercial grade device. But I have never had one once of problems with any of them, ever. This is the part number: TWRBR20W-SPL I order mine online, but any Electrical Supply House keeps them in stock.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is online now   Reply With Quote
Old 05-31-2019, 01:02 PM   #5
Rewards Points: 58
I changed out all dvics at a job recently thhat we're back stabbed when the house was built in 2006. 20% were firmly attached, 60% had some resistance to remove, and 20% literally fell out on their own. Not a good record on over 100 devices.
Wiredindallas is online now   Reply With Quote
