Attic Fan E62815 EPC - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 04:43 PM   #1
E62815 EPC
I have the detailed Fan installed at my home and it has stopped working, (was not serviced ever and went through it's life cicle)
I would like to buy a new one, but exactly the same dimentions so that I do not change all the installation that there is set up for it, the round hole where it is mounted is 15 inches in diameter and the fan is a four blade, just under 14 inch diameter, the motor is 5 inches in diameter and about 3 inches thick, it's a 115 volt 60 HZ 4 amps unit.
It seems to come attached to the adjustable temperature thermostat but what has failed is the electric motor.
John Mackenzie is offline   Reply With Quote
Old 06-07-2010, 07:09 PM   #2
Master Electrician
Rewards Points: 5,082
Yes, I agree.
brric is online now   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 08:56 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
