Anyway To Remove This Box - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Fishbulb28
Old 03-01-2017, 08:09 PM   #1
Rewards Points: 47
Question
Anyway to remove this box
Without climbing into the ceiling or cutting into it from below? Because I see it has those older conduit fittings that have the hex nut above/inside the ceiling. But I'd rather cut into the ceiling if I have to rather than crawl around up there.
Sliding Man is offline   Reply With Quote
Old 03-01-2017, 08:47 PM   #2
Property Mgt/Maint
Rewards Points: 7,626
Re: Anyway to remove this box
Well before you take out a box, you need to disconnect all the wiring. Why are you removing it?
Just a warning, be prepared for anything. Your box was wired, or at least modified by a rookie. A professional would not tie in ground wires under the cover screws
Yodaman is offline   Reply With Quote
Old 03-02-2017, 02:34 AM   #3
Rewards Points: 47
I want to install a ceiling fan here with either a brace or box fastened to the joist.
Old 03-02-2017, 05:35 AM   #4
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 2,070
I don't think you'll be able to avoid working in the attic/crawlspace above the room. The current box is installed via a hanger bar and I'm pretty sure I also see a gap on all four sides of the box. That means the box isn't adjacent to any joist you can use. You'll have to use a fan rated box and hanger.
I know of no fan rated box/hanger combination that will support the conduit configuration you have now. At best I can think of a couple of models with two usable top entry knockouts. Maybe someone here is familiar with one. If not, you are going to have to rework the conduit into a separate box accessible in the attic.
Also, is the present light fixture working? There is a 'slight' anomaly in the wiring...
jeffmattero76 likes this.
Fishbulb28 is online now   Reply With Quote
Old 03-02-2017, 07:24 AM   #5
Rewards Points: 18
Fish - are you saying you never saw blacks and grounds tied together before??? LOL
If this is, in fact, working, the switch must be breaking the neutral.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 03-02-2017, 09:00 AM   #6
Rewards Points: 637
I can't completely see the wiring, but I think, if this works, then the green wire is used for hot.
csab_ is offline   Reply With Quote
Old 03-02-2017, 09:00 AM   #7
Rewards Points: 2,084
Take that mud ring off. Label all of the wires so you can put them back together the way they were. Disconnect all of the wires and straighten them out. I am not sure what kind of connectors are in the back of the box, possibly plastic buttons. Remove the center screw and stud. The box should come down after that. Gently remove the cables from the box. Do not cut any wires. If there is a bar going across from joist to joist it will need to be removed. I usually use a bolt cutter to cut it in half, but a reciprocating saw will work also. The hard part is removing the two cut pieces from the joists. I have small pry bars that fit up in the hole and I can reach the joists and pry the pieces away from the joist. Wear gloves as you get a lot of cuts and bruises on your hands.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 03-02-2017, 07:01 PM   #8
Rewards Points: 312
you could cut away enough ceiling to install bracing to support the box and weight of the fan. Wouldnt have to remove any wiring for that...
KPDMinc is offline   Reply With Quote
Old 03-03-2017, 01:37 AM   #9
Rewards Points: 47
The light works. The switch has a black wire on the bottom and a blue on the upper terminal. Probably the same blue wire in the ceiling going to the light itself. All the black and whites are tied together. The bare wire I believe is the ground for the fan in the living room. I had the ceiling repaired a couple years ago and had them install a ceiling fan with new wiring while they were here. These are the connectors that seem to be everywhere in the house. They seem to be impossible to remove from below.
And the ones used by the kitchen and bath fixtures.
Old 03-03-2017, 07:37 AM   #10
Property Mgt/Maint
The wiring issue is your "blue" conductor looks green, which normally in a conduit indicates ground. Then we see green to black connected.
Thinking someone was short a conductor and swiped the ground for a hot.
Is your new work being inspected? If yes, better correct it now.
Old 03-03-2017, 07:56 AM   #11
I don't recall ever seeing conduit connectors like those.
I did not realize that the box was fed with pipe. Forget about removing that box. I am not aware of a fan rated square box. To get a round box in there will be a lot of work.
I think a good option for you is put a 2"x 4" or a piece of strut across the joists and drop down two threaded rods to hang the fan off of. The wood or strut would need to be screwed down to the joists. The rods would need to be secure with nuts on each side of the wood or strut. You will probably need to drill holes in the mud ring. This way the fan will be independently supported.
Maybe some of the other pros can chime in with their tips and tricks for hanging a fan on this box.
John Grabowski
MrElectrician.TV
Want to remove wall in kitchen, possible? mikereno1 Building & Construction 7 11-11-2016 01:06 PM
can i remove Amitabh Building & Construction 0 06-08-2016 07:42 PM
How to remove shower pan? timnancyk Plumbing 17 01-11-2016 04:06 PM
need to refinish me pressure treated deck AND remove cabot SPF - NEED INPUT Kirchf Painting 0 05-27-2015 12:19 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 10:09 PM
