Any Rules On What Direction Wires Enter And Exit A Light Switch Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 12:01 PM   #1
Any rules on what direction wires enter and exit a light switch box?
Read something about hot coming in on the bottom. Is it OK to use top knock outs for all wires if convenient? Thanks.
Mi Feller is offline   Reply With Quote
Old 06-28-2010, 12:05 PM   #2
Licensed electrician
Rewards Points: 3,654
No restrictions. Some do like to bring the power feed into the KO nearest the stud, but no requirement to do so.
Mi Feller (06-28-2010)
Old 06-28-2010, 12:39 PM   #3
Jim, thank you very much for prompt response.
Old 06-28-2010, 01:25 PM   #4
Handyman
Rewards Points: 520
top or bottom depends on where the feed is coming from but I also like to run the hot into the KO next to the stud..this way it helps troubleshoot if something goes wrong
canadaclub is offline   Reply With Quote
