Another Puzzling Question About GFCI Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 10:55 AM   #1
Another puzzling question about GFCI outlet
I have installed about 10 GFCI Recepticles throughout my home. I know how to wire them.
This particular outlet protects two outlets at the kitchen sink, two lower mounted outlets, and three small undercounter florescent fixtures. The outlet trips when the lights are turned OFF. I have replaced all three undercounter fixtures and the light switch. These new fixtures have a switch on them and I have tried isolation. With all fixtures off, the outlet will not trip.
I have checked all wiring and no situations like, ground touching neutral, exists.
Why would a GFCI trip when power is switched off?
Giles is offline   Reply With Quote
Old 02-20-2010, 12:12 PM   #2
Rewards Points: 506
Have you tried replacing the GFI?
jlmran is offline   Reply With Quote
Old 02-20-2010, 12:39 PM   #3
Rewards Points: 2,800
Only at the moment the light is switched off?
Or again when you push the reset button and the light is still off?
It is possible for a fluorescent light to release a small surge into the line as the light is turned off and this might trip a GFCI.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 02-20-2010, 01:00 PM   #4
Yes-- I have experienced that in the past. That's one reason I replaced the fixtures.
The outlet doesn't trip every time the lights are TURNED OFF. Once in four or five cycles, which is too many.
I may have to run the lights from a non protected circuit, which I rather not do in the kitchen.
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 02:23 PM
Outlet Wiring Question (Please Help!) joshg3p0 Electrical 34 02-05-2010 01:40 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Welder outlet question coyote556 Electrical 4 12-03-2007 03:30 PM
GFCI outlet vs. breaker - GF trip speed LanterDan Electrical 2 01-09-2007 06:05 AM
