You say you "...got the electrical work in my house done..." Does that mean you had an electrician do it? Or did you do it yourself?
If you used an electrician, this is his/her problem. But I suspect this is your work. And I have to assume that your "...15 amp GFCIs for each of the two bathrooms..." are Ground Fault OUTLETS that were installed in existing boxes in the bathrooms and not Ground Fault breakers installed in the breaker box. It does not look like there are any Ground Fault breakers in the breaker box, but I am not familiar with the appearance of every one ever made.
Things to check:
1. Does power actually get to those bathroom boxed? A neon tester can quickly determine this.
2. Is the incoming line to those boxes actually connected to the Line terminals of those outlets? Most Ground Fault outlets have pass thru terminals which allow additional, standard outlets to be connected downstream of the GF outlet and have the same protection. But these pass thru terminals can not be used to provide the power to that initial GF outlet. You MUST use the proper terminals on them.
3. Is there a proper ground in those boxes and is that ground actually connected to the GF outlets? If these are plastic boxes, you may need an individual ground wire connected to the green terminal on the GF outlets. If it is an older building there may not be a ground wire from the breaker box to these boxes. If that is the case, please DO get a proper ground run, even if you must employ an electrician to do it.
If those three things (power to the box, proper connections, and a ground) were done properly, the GF outlets should work. It is unlikely that you got two bad GF outlets, but it could have happened.
Please do this with care. Turn the breakers off before opening the boxes. Test all wires for power with a neon tester (not a meter which can easily be burnt out - and YES, I have personally seen that happen) before touching them. Only turn the breakers on when live power is actually needed for testing and be extra careful then. Kill the power again before any work or before re-closing the box. And, if at all possible, have someone there while you are working. DO NOT DO IT ALONE! Far more knowledgeable people have been killed while working with electricity alone. I would be considered a professional and an expert, but I have been bitten. Once by 40,000 Volts and I can assure you it is no picnic.
As for the outlets you need for the kitchen and outdoors, you need to consider the things that they will power and the circuits that they will be installed in. If they are 20 Amp circuits, then either 15 or 20 Amp outlets are OK. If only 15 Amp circuits, then I would urge you to either upgrade or to consult with a licensed electrician or the local city/county inspectors.
I just got the electrical work in my house done and used 15 amp GFCIs for each of the two bathrooms. Neither of them work. Why is that? Even if they were installed on a 20 amp circuit, shouldn't they work? As far as the load on the electrical system, I'm the sole inhabitant of the house, but I do have a fair amount of electric and electronic items.
I also need to get GFCI outlets for the kitchen and outdoors. Would 15 amp be OK for that?
Here's my electrical box, for reference. I know one of the 20 amp breakers was switched off but I turned it back on after the picture was taken. The numbers on the box are hard to read so I wrote them in more clearly. That black square is to cover up a permit sticker that has my address and town name on it.
